Transmission issue, now no start? Help!
I'd go with a new set of "Really good batts" Interstate....etc. Look hard at non prorated warranties and keep the paper.
My 99 7.3 is my driver and plow truck that I work heavy in the winter here up North and I get two years out of the top batteries despite care and maintenance. (probably because of the plow).
(the 08 my wife drives until mine gives it all up F350 cc srw is sposed to be my replacement, but that's yet to be seen). It's got girl stuff hanging and clinging and she keeps ordering decals for the nose and bumper etc.. Unknown how that turn over will play out.
It's a SC truck, no rust, Jade green (that's what she named it) "Jade" 100k. I'm pretty good on the 7.3's but really just diving into 6.4's. Different, but peculiarly similar in terms of diagnosing hits and misses.
Hope things work out to something easy and cheap. I'm ever watchful.
Denny
Denny
I wonder if the ground connections on the battery cables were bad. Pulling them and then hooking them back up fixed it?
10 years is a long time for batteries, that's for sure. But not unheard of. I think a couple guys on the 7.3 forum got something like that on their original batteries if I'm not mistaken.
Going to be interested on the load out. I'm shooting at a dead cell on one or both. Taking a crap shoot, a dead cell would keep the alt excited all the time and blow a few minds in terms of PCM, GEM and whatever other jewels the hid since the 7.3.
Hawking this.
Denny
Hawking this.
Denny
been running fine since yesterday. Cranks fine, like normal. It was -7° this morning, and it fired right up with no hesitation. I have started it about 20 times since yesterday when I hooked that batteries back up. I am still going to look at new batteries.
Everything including batteries look like they're dead on. You are due for batteries, but for the life of me I can only come up with a voltage related issue to put you where you were.
Still scratching my head. Is there a chance that when you cleaned up the terminals and moved the wiring that there might be a cable chafed thru somewhere and just the act of repositioning the cables slightly, removed contact somewhere.
Only (long shot) thing I can come up with.
Just blows me away that your dash was clear and bright which would can that theory.
Denny
Denny
Denny
Denny
Looking at schematics, I see that the trans temp sensor and the PRNDL indicator for shift positioning and display are on different planets. Kinda makes me wonder if you had it filled/flushed in June as reported, the sensor wire may have been loose. Doesn't get me to the good place with the indicator tho. I'm researching............. Mark is the main trans ex ford engineer for trucks in the 7.3 forum. I'm not sure he hawks the 6.4 as I believe he retired prior. I'll reach out to him and see what his take would be.
He's the god in the 7.3 forum for trans related issues.
Another thing I can't wrap my arms around is the no start condition having anything to do with it, unless it's a safeguard.
I'll report.
Denny
I'll report.
Denny
Thanks I appreciate your help. When I changed the transmission filter and fluid, I did it myself in my driveway. Drained the old fluid, pulled the pan changed the filter-yes I got the old o-ring out, cleaned pan, reinstalled pan, and added 10 quarts of new fluid. Drove truck for 300+ miles and drained fluid, added another 10 quarts. 10 quarts is what I measured of drained fluid. I refilled 9 quarts and drove it, adding a little more as I drove around. That was July 9.
#30
so all has been good for the month, but today I went through the car wash and the same thing happened. Mark, I sent you a PM but I would love a little help as to where that harness is located?
