need help with T-case shifter measurement
Hi fellas,
I am in the process of building a NP-205 (swapped in) twin stick shifter for a '72 highboy that is currently torn apart and scattered across 2 counties so I cannot measure a shifter in a cab like I need to.
Could someone please tell me how high the shifter shaft is above the floor pan with the t-case in 4wd (as close to vertical as it can get) and perhaps measure to the chamfer on the shaft just before the threads start?
Thanks for any help!
billest
10-24-2013 08:28 PM
