1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What does my truck weigh?
Old 12-16-2016, 04:39 PM
Rob89's Avatar
Rob89
Rob89 is offline
I'm sorry if this has been covered before but I'm just trying to figure out a ballpark number of what my truck weighs. The nearest CAT scale is a ways away from me so just trying to figure out my own ballpark number. My truck is a 2016 f-250 ccsb Lariat 4x4 6.2. According to the ford specs the base curb weight for my truck is 6828. Add in 200 pounds for myself, about 200 for gas and 50 pounds of miscellaneous junk in the bed and I'm looking at just shy of 7300. I'm not sure how much weight the lariat package adds with running boards, power seats, carpet etc. So I'm thinking I'm somewhere around 7500 rolling down the road with a full tank of gas.
am I way off base with my numbers?
Old 12-16-2016, 04:44 PM
Tom's Avatar
Tom
Tom is online now
You sound in the ballpark. Check the payload sticker in your door jamb, then subtract that from your GVWR. That should give you the weight of the truck as it left the factory.
For example, 9,200 lb GVWR - 1,900 lbs payload = 7,300 lb empty weight.
Old 12-16-2016, 05:20 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
My 2016 CCSB 4x4 6.2 XL with nothing in it and 1/2 tank of fuel: 6800 lbs. I think you estimate of 7500 lbs is going to be really close.
Old 12-16-2016, 06:43 PM
seville009's Avatar
seville009
seville009 is offline
You're about in target at 7,500. I had modifications on mine and took it took a local truck stop to check it on the scales - was at 7,800 I think with me and other junk in it.
Old 12-16-2016, 07:14 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
You are in the ballpark with the 7,500 pounds.
Old 12-16-2016, 07:43 PM
Rob89's Avatar
Rob89
Rob89 is offline
Thanks for the help! The scale is too far to drive out there for no reason however next time I have a reason to head out there I'm definitely getting weighed.
Old 12-16-2016, 07:48 PM
mapitts66's Avatar
mapitts66
mapitts66 is offline
RainDesert, what kind of sign/signal is that???
Old 12-16-2016, 08:27 PM
14SD4Jeffro's Avatar
14SD4Jeffro
14SD4Jeffro is offline
digital scale weight..my educated guess would be at a weight scale
Old 12-17-2016, 05:26 AM
ugh3012's Avatar
ugh3012
ugh3012 is offline
1900 pounds left? Not much of heavy duty truck.
Old 12-17-2016, 06:40 AM
Tom's Avatar
Tom
Tom is online now
Both my '08 and '11 Super Duties had under 1,900 lbs of payload available. 10,000 lb GVWR and diesel Crew Cabs. My current F150 has 1,830 lbs, but of course it can't handle anywhere near the towing weight or duty cycle of the Super Duties.
Old 12-17-2016, 07:47 AM
FordmanNJ's Avatar
FordmanNJ
FordmanNJ is offline
2011 F250 XLT CCSB pretty loaded on options.
When I first got the truck. I was around 7400 pounds. With the current load out of the truck, I am around 7700 pounds last time I was at the scale. GVWR 9600 pounds. So sub my weight the truck would be currently sitting at 7500 pounds. Not to shabby. Then again, I have had nearly 4000 pounds in the bed without an issue.
Old 12-17-2016, 09:11 AM
ugh3012's Avatar
ugh3012
ugh3012 is offline
Seems like we all are exceeding GVWR all the time. My truck has the brush guard and auxiliary fuel tank. It's 8,800 GVWR. We use it to pull the camper. I am sure I am over loaded. I will weight it some day.
Old 12-17-2016, 09:21 AM
Tom's Avatar
Tom
Tom is online now
You're not gonna hurt anything. Your truck has the exact same axles and brakes as an SRW F350 with a 11,500 lb GVWR.
Old 12-17-2016, 09:35 AM
RainDesert's Avatar
RainDesert
Those are our ODOT(Oregon Dept of Transportation) scales, they leave them on when they are not stopping trucks there. I have weighed at others and the landfill. My truck, and my current one (6500#), always show the same weight between them.
Old 04-27-2021, 04:15 AM
Roy Cobb's Avatar
Roy Cobb
Roy Cobb is offline
Light load
Light load 19 rolls roughly 1000lbs each
ezduzit01
30
01-13-2015 11:43 AM
adamsre
2009 - 2014 F150
07-09-2011 02:45 PM
zr800
2004 - 2008 F150
01-17-2005 07:49 PM
Stampede
1997 - 2003 F150
02-29-2004 04:40 PM
4x4x4x4
43
12-05-2002 12:43 AM
Quick Reply: What does my truck weigh?
