thermostat or climate control issue??? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-14-2016, 02:05 PM
weyland426's Avatar
weyland426
weyland426 is offline
weyland426 has a very good reputation on FTE.weyland426 has a very good reputation on FTE.weyland426 has a very good reputation on FTE.
A new issue that just started is my heater putting out very cold air intermittently. I just today noticed that my engine temp goes from 170's to 190's when this happens (outside temp was 16 today), lasts for a few minutes then returns to normal heat and engine temp. Did it 3 times in a half hour trip at highway speeds today. I just had a blend door replaced last month so I am curious if this may be a symptom of another climate control problem or a bad stat? I did confirm that my coolant level was good and other than a bad glow plug code and CEL, tuner shows nothing else. Any insights?? Thanks.
Old 01-11-2017, 07:38 AM
weyland426's Avatar
weyland426
have in a shop today who says this is likely a leaky head gasket sucking air at high temps causing a bypass of the heater core. this make any sense?
Old 01-11-2017, 09:30 AM
jimh425's Avatar
jimh425
jimh425 is offline
jimh425 is starting off with a positive reputation.
Not saying it is impossible, but how did they determine you had a leaky head gasket?
Old 01-11-2017, 09:52 AM
weyland426's Avatar
weyland426
I lose approx one-half gallon of coolant every couple thousand miles and have already had the EGR coolers removed.
Old 01-11-2017, 11:37 AM
jimh425's Avatar
jimh425
jimh425 is offline
1/2 gallon per couple of thousand miles would probably be enough proof. Yikes!
jimmy-six
2015+ F150
21
03-04-2018 02:43 PM
Retreever
1999 to 2016 Super Duty
05-24-2017 10:23 AM
f150country
12-01-2016 10:53 PM
kegger66
11-30-2016 08:13 AM
2001NaviA4WD
1997-2006 Expedition & Navigator
06-28-2016 07:56 AM
Quick Reply: thermostat or climate control issue???
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
