washer pump and nozzle upgrade
I need to get my windshield washing system up to snuff. I like the 80's and 90's catch/washer pump combo but, I already have a catch tank. I could ditch that but, there is a second battery in the location where it would normally mount.
The stock nozzles aren't the best. Do they spay in a fan pattern when operating normally? Because mine sure don't. Really don't do much at all.
What's a good pump and nozzle upgrade?
My '77's washers just shoot a stream up into the center of the swipe area that hits from about 1/3 way up to near top and gravity pulls some back down. There is no "fan" pattern to them. The wiper blades do the spreading.
Dorman has a kit with different nozzles but they mostly mount hood side for newer stuff.
I have OEM tank with a replacement pump and new hoses. I did modify later WW arms from a late '80s-'90s PU to use new style easily sourced on the road blades.
https://www.ford-trucks.com/forums/1...50-thread.html
Pretty much the same experience - had no washers, replaced the washer motor with one from the local auto parts store (no need to order, in stock and I seem to recall $15) - worked like a champ when I jumpered to it but I could not get juice to it. Wound up discovering that some PO had replaced my WW switch with an incorrect model missing the 'washer' function. Bought a new correct switch, so I have both washers and interval wipers - life is good.
Two different types of windshield wipers, two different wiper switches.
Two speed wiper switches have a low & high speed.
Intermittent (delay) wipers were optional on 1973/79 F100/350's and 1978/79 Bronco's. Intermittent is not another name for low speed!
DOOZ-17A553-A .. Two Speed Wiper Switch-Not used with intermittent wipers (Motorcraft SW-896) / Marked: D0OB-17A553-A or D / Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1970/71 Fairlane/Torino/Montego / 1970/72 Maverick/Comet.
SUSANVILLE FORD in Susanville CA = 530-257-2137.
NOS ONLY in San Jose CA = 800-667-6659.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
D1OZ-17A553-A .. Two Speed Wiper Switch-Used with intermittent wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
NOS ONLY
BURNS FORD in Burns OR541-573-7278.
GREEN SALES CO.
And D1OZ-17A553-A ..Two Speed Wiper Switch-Used with intermittent wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
DON'S TRUCK SALES in Fairbank IA= 319-365-2751.
MCDONALD OBSOLETE PARTS CO. in Rockport IN= 812-359-4965.
WESLEY OBSOLETE PARTS in Liberty KY= 606-787-5293.
GREEN SALES CO. in Cincinnati OH= 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC = 800-476-9653.
There are TWO different intermittent wiper governors. 1973/77 is one type, 1978/79 is another.
D3TZ-17C476-A (replaced D1ZZ-17C476-A) Intermittent Wiper Governor / Obsolete
You will probably need to locate the box also. And the red plug adapter wiring harness. Ck out 80's/90's(?) ish Ford trucks also. That might call for a bit of re wire of the box??
NOS ONLY
GREEN SALES CO.
