****Window Trouble
Old Dec 13, 2016 | 09:50 AM
diesel_doll's Avatar
diesel_doll
Unhappy ****Window Trouble
So I have been driving our 66 F-100 to and from work for the last 2 days since my super duty is down for paint. (First time driving manual) Last night, the drivers side window fell off track and the hubby fixed it telling me I was slamming the door too hard and the window cannot be all the way rolled down. This morning I had it in the back of my head to do it as gently as possible, with the window still sticking up a bit as he showed me, and it still fell back down. How do I fix this, considering I am trying to close it as gently as possible. Is there something I can do to better hold in the window?? New parts?? PLEASE HELP!
Old Dec 13, 2016 | 10:02 AM
Freightrain's Avatar
Freightrain
You're in the wrong forum, you need the next one down.
BUT, it sounds like something is damaged in some way. You should be able to slam the door and NOT have the window fall. Something is worn out/broken. The regulator? The sissor mechanism that moves the window? Can't say til you pull the door panel and see.
Old Dec 13, 2016 | 01:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The window regulator uses a nylon window roller (COAB-6423240-B). It fits onto the stud of the regulator, then inserts into the window channel that the glass is adhered to.
The roller breaks, the window falls down into the door, which is a very common problemo.
The roller was used on all 1961/66 trucks, 1960/64 Galaxies, 1960/65 Falcons, 1962/65 Fairlanes and 1965/66 Mustangs.
It's available from all the repro parts sellers and....since you live in AZ:
STEVE COURY FORD in Star Valley AZ has 2 = 928-474-8888
DON SANDERSON FORD in Glendale AZ has 9 = 623-842-8682.
Old Dec 14, 2016 | 03:35 PM
JEFFFAFA's Avatar
JEFFFAFA
True story. We do have 9 of them.
Old Dec 16, 2016 | 09:33 AM
orich's Avatar
orich
Please let us know of your fix for this problem as we like to have closure to everyone's post even if you are in the wrong web forum page.
Thank you!
Orich
dcmania
May 2, 2017 05:50 AM
Sam's1967
Jun 7, 2015 01:09 AM
chefcharles
Feb 15, 2014 09:49 PM
fishnative
Nov 15, 2012 05:44 AM
Back265
Jan 19, 2010 08:07 PM
