What flywheel bolt pattern?
Hello 6.2 fans. I have the opportunity to buy a low mileage 6.2 engine from a wrecked 2015. There is no trans offered with it and I wouldn't want a computer controlled auto anyway.
From everything I've read it seems to be the perfect engine to retrofit into my '76 F250. I would like to put an NV4500 behind it but I need to know what flywheel would bolt up if any. Does anyone know what the crankshaft bolt pattern is?
No experience but I'm a fan of the 6.2. Everything I've read said it was a modular bolt pattern. Don't know if it's a 6 or 8 bolt crank. If that's true being modular you should be able to find something from the larger truck with 5.4 engine. If you do figure it out let us know. I have a 6.2 in a SD and am impressed with the power over the 7.5 it replaces. Time and technology I guess.
I tried to send Mark K. a PM but it was unsuccessful. It appears he does not accept PMs. Thanks anyway.
Oliver Herting
06-10-2017 09:09 PM
Kuskoal
05-04-2009 11:15 PM
