bad fuel pump check valve?
Received 3,099 Likes
on
if i start my 2014 with the remote it runs fine by the time i get outside.
if i get in the truck and start it cold, and put it in gear it dies like it runs out of fuel. then takes about a minute to restart. then runs fine.
does this sound like it is loosing fuel pressure after sitting?
i am "new" to computerized gas engines, having run diesels for the past 35 years, or carburetor gas engines.
also, every 3-4 starts with the remote it will only beep the horn instead of start the truck. is there a way to make the remote start work with only double tapping the start button instead of pushing the lock button before the start button?
Trailblazed
18
10-23-2007 02:34 PM
