1994 F150 Horn & Cruise Control problem - Page 2 - Ford Truck Enthusiasts Forums
Old 12-01-2014, 04:47 PM
drdouglas
drdouglas is offline
drdouglas is starting off with a positive reputation.
I have a 1994 F-150 5L. The cruise and the horn do not work and the airbag light has been blinking. I have checked the fuses and the brake pressure switch. Do I need to check into the clockspring next?
Old 12-01-2014, 05:25 PM
88n94
88n94 is offline
88n94 is gaining momentum as a positive member of FTE.88n94 is gaining momentum as a positive member of FTE.
Yes, almost certain it is the clockspring. My '94 has had those symptoms since I got it. As mentioned earlier in this OLD thread, be CAUTIOUS of the AIRBAG.
Old 12-13-2017, 10:11 PM
WILLYPete
WILLYPete is offline
WILLYPete is starting off with a positive reputation.
Originally Posted by PAUL_2 View Post
Is the SRS / airbag light on or blinking ?
I have a similar problem. Horn and cruise doesnt work. Also the airbag light is blinking. How do I fix that?
Old 12-14-2017, 07:57 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Welcome to FTE!
You should start your own new thread instead of tagging onto one that started 16 years ago.
Without reading back through everything posted over that period the most likely cause of your issue is a broken "clock spring" located behind the steering wheel. The airbag light is flashing out an error code. Those have a meaning and will point you to what it thinks is wrong.
rusty86cj
1999 to 2016 Super Duty
11-09-2017 06:54 AM
Thoth88
10-31-2017 07:02 AM
timbersteel
28
09-07-2017 05:06 PM
1997Aerostar
Aerostar
04-30-2017 08:41 PM
Gary Newberry
1978 - 1996 Big Bronco
01-21-2017 04:36 PM
Quick Reply: 1994 F150 Horn & Cruise Control problem
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
