This is a photo of what I monitor with my CTS2. The truck was not running nor has it been started in the last 24 hours.
Since everyone complains that the fuel gauge is inaccurate, is the Fuel % accurate? If you had a 34 gallon tank and had 5% left then when you filled it up it should take around 32 gallons.
thank you I see they have 2 different versions available. do you find that it sticks out from the dash too far and get in the way? its kind of hard to see from the website pictures
I have the 65 gallon Titan tank. It does take about 10 to 15 gallon for the Fuel % and the truck gauge to move. Once they start moving, they are pretty much hand in hand.
I also reset Trip A every time I fuel up. I know the approx gallons used prior to stopping for fuel. For most part, what the Trip A shows as fuel used, is usually within a gallon of what i put back into the tank.
Ford has a history , as far back as I can recollect, of the gauge reading empty and still have approx 2 to 3 gallons left in the tank that is usable. The amount varied depending on the vehicle and fuel being used.
Had Edge released a dash pod for the later model trucks? Or where mods needed to use the older pod with the one piece dash pad?
The XL and XLT still had the dash design of the 2012-older trucks so only a small amount of trimming was needed to get their dash pod to work. This pod won't work on 2013-newer Lariat or higher trim levels.
How accurate is the DPF Load %? On my original CTS in my 2013 it was quite good at predicting a regen, but I just put a CTS2 in my 2016 and it has only gone from 4% to 0% so far, and I've had a regen. Maybe it will correct itself after more time with the truck. The Ford DPF screen showed 80% when it started the regen and 40% when it was done.
