crewcab door glass question
I do believe that is a yes. 1973-1979 Bronco & F-Series Truck Weather Stripping
X2 on YES use a hack saw blade with some tape as a handle and yes blue mask tape the part your arm rests on and all the way around the panel to prevent scratches.
I hope you have the plastic push pins and NOT the metal ones. Metal ones are a PITA. Or just get a door panel removal tool.
Or make one out of a large #4 flat tip with a V notched in the end and a 45 bend 3" up from the end. Or just pray, steady pull pressure, and finger tips on each side of the pin.
Use these come replacement time, GM ones are longer. Also notch the door panel behind the finger cup to clear the 2 bolt heads. No worries the finger cup covers it. That way it will fit tighter, also get some metal finger cups from LMC way better.
I reinforce the plastic tab under the finger cup.
Do not panic it you break off a tab, I have spares pieces that you dremel shape and then 2 part epoxy on. And if you get in a real bind I am sure you can locate a set on here.
CC forum https://www.ford-trucks.com/forums/7...ly-thread.html
I would like to Burmese round house tight kick the guy that put that speaker cover in the blue set...yes he cut the hole for the speaker.
terceslil
17
03-26-2010 08:50 AM
