Block heater questions
So I plugged in my block heater last night and when I start the truck this am it was obvious that it didn't work. This is the first winter I have had the truck so I have no history on the block heater. It's a 96 with 95k on the odometer. So here are my questions. What should I check first? Is there a fuse? Where is the heater located? Is it difficult to change? Luckily this truck will start no problem in the cold but it would be nice to have a little heat when I leave early in the AM.
And after your research, you can get under the truck on the driver's side of the block above the oil filter and look.... Just follow the cord.
90% of the time, the element is good and the cord is bad. You could try replacing the plug and save some $$.
Word of caution, if you replace the heater, drain your coolant first.
Guess I'm too dumb to figure it out. Of the hundreds of threads that it listed I did not see any in the 94-97 diesel section that answered my question. Definitely hundreds of threads listed though.
This is the cord I purchased some time ago. You can also get a cover for it as well.
https://www.amazon.com/Kats-28216-He...F4Z0ND7YNQ0JKP
I put a 15 amp timer on mine and just have it come on a couple of hrs before I leave the house.
Saves a ton of money on the electric bill. I think most pull around 9 -10 amps 1100-1200 watts. Most indoor home timers will carry the load.
I always said if I ever got to where I could help a new guy, I would never tell them to hit the search function if the answer was not as long as a novel.
02GrayPowerStroke
64
01-28-2010 10:47 PM
