New to me '96 F350
replacing the fuel pup is fairly easy but you need one big wrench for the banjo fitting and it takes time turning it a 12th of a turn and flipping the wrench back n forth
I removed the bowl and turbo Y pipe when I did mine, made it easier to get in.
Replace the hoses on the bottom, mine were bulging and leaking a lot. Don't use regular fuel hose, it will fail.
can order from here
Ford - 94-97 'OBS' 7.3L - Fuel System & Related - Fuel System O-rings, Sleeves & Hoses - Riffraff Diesel Performance
can order from here
The_Josh_Bear
63
07-27-2016 10:09 PM
