16 spark plugs, cab comes off?
Procedure for Spark Plug replacement from 2015 Ford Service Workshop DVD...
Spark Plugs
Removal
NOTICE: Do not remove the spark plugs when the engine is hot or cold soaked. Spark plug thread or cylinder head damage can occur. Make sure the engine is warm (hand touch after cooling down) prior to spark plug removal.
NOTICE: If a spark plug is dropped, internal damage may result and the spark plug must be discarded. The use of a damaged spark plug may cause cylinder misfire resulting in engine damage.
Upper spark plugs
Remove the ignition coil-on-plugs, refer to Ignition Coil-On-Plug in this section.
Lower spark plugs
Disconnect the ignition wire from the lower spark plugs.
All spark plugs
NOTICE: Only use hand tools when removing or installing the spark plugs or damage can occur to the cylinder head or spark plug.
NOTE: Use compressed air to remove any foreign material from the spark plug well before removing the spark plugs.
Remove the spark plugs.
Inspect the spark plugs, refer to Section 303-00 .
Installation
All spark plugs
Adjust the spark plug gaps as necessary. For the correct spark plug gap specification, refer to Specifications in this section.
Install the spark plugs.
Tighten to 24 Nm (18 lb-ft).
Lower spark plugs
Connect the ignition wire to the lower spark plugs.
Upper spark plugs
Install the ignition coil-on-plugs, refer to Ignition Coil-On-Plug in this section.
Spark Plugs
Removal
Upper spark plugs
Lower spark plugs
All spark plugs
Installation
All spark plugs
Lower spark plugs
Upper spark plugs
Spark Plugs
Removal
Upper spark plugs
Lower spark plugs
All spark plugs
Installation
All spark plugs
Lower spark plugs
Upper spark plugs
Spark Plugs
Removal
Upper spark plugs
Lower spark plugs
All spark plugs
Installation
All spark plugs
Lower spark plugs
Upper spark plugs
fordinmudd
06-23-2010 11:24 PM
1954blueoval
05-08-2005 08:43 PM
