FORScan and As-Built Data - Page 66 - Ford Truck Enthusiasts Forums
  #976
Old 12-15-2018, 02:51 PM
dkeyt7
dkeyt7 is offline
dkeyt7 is starting off with a positive reputation.
Ok I had my headlights in auto and could not get any of the DRL settings to work. I got bambi mode to work without any issue so that is why I was confused. I will try again and see if I have any luck but I could not get 1, 2, or 3 to work in lieu of the 0 that is "stock"
Thanks,
  #977
Old 12-15-2018, 07:13 PM
jav_eee
jav_eee is online now
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
Thanks,
You need to be in a gear other than "park" when you check to see if they work.
  #978
Old 12-19-2018, 11:34 AM
dkeyt7
dkeyt7 is offline
I noticed the codes dont match my 2015 in the posted sheet for showing DPF%. Are those codes only for specific years? Other question/comment, looked like forcing regen on 2015 is not possible? i couldnt get anything to pop up to ask me to manually regen. Everything else is working great, THANKS!
  #979
Old 12-19-2018, 11:50 AM
Just Strokin
Just Strokin is offline
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
Those codes are for all years. I am not sure why you codes might be different. Maybe you are looking at something else? The only time one would get the opportunity to do manual regen is maybe on XL and XLT trucks. There is only one person who has claimed to have the message to do a manual regen on his 215 Lariat.
What does your line read?
721-01-01 **** **** **** X*** (X can be E, F 6 or 7)
  #980
Old 12-19-2018, 12:13 PM
dkeyt7
dkeyt7 is offline
Thanks for the info. I will send a snip of my codes later. I have the one you mention above but I dont have the same for the DPF % screen, I believe. I will double check.
  #981
Old 12-19-2018, 06:48 PM
ajorn's Avatar
ajorn
ajorn is offline
ajorn is starting off with a positive reputation.
I recently purchased a 2012 F250 with a titan tank in it. The fuel gauge is still reading the stock tank size, when the guage is close to E and I fill up I only put 21 gallons in. I've tried to edit the settings both in the as built and the other IPC menu but still can't get the fuel gauge to read correctly - any thoughts?
  #982
Old 12-19-2018, 08:10 PM
Just Strokin
The tank size change only deals with miles to empty calculations. It has nothing to do with the actual gauge indicator. Personally, I do not worry about the gauge but I watch the gallons used in Trip A. I reset Trip A at each fill up. Then I know aprrox gallons used and hose much is left in the tank.
  #983
Old 12-27-2018, 09:57 AM
Stevem4134
Stevem4134 is offline
Stevem4134 is starting off with a positive reputation.
Due to good weather and about 22.5K miles on my 2011 F250 6.7 I changed both fuel filters. At that time, the Replace Fuel Filters message was not being displayed. How can I reset it if it is not displayed under the maintenance screen?
  #984
Old 12-27-2018, 08:22 PM
jav_eee
It's in the info center. I believe under vehicle info at the bottom.
  #985
Old 02-15-2019, 08:41 PM
Mikes88Stang
Mikes88Stang is offline
Mikes88Stang is starting off with a positive reputation.
I created a folder and added my as-built detail. Where can I get a window sticker generated by my VIN to include?
  #986
Old 02-16-2019, 09:50 PM
ILBCNUL8R
ILBCNUL8R is offline
ILBCNUL8R is starting off with a positive reputation.
Try this link
  #987
Old 02-17-2019, 06:49 PM
Mikes88Stang
Originally Posted by ILBCNUL8R View Post
Try this link
says its not yet available. I know I had grabbed it off the ford dealer site when I picked up the truck...Iíll look a bit harder.
  #988
Old 02-17-2019, 07:10 PM
Just Strokin
Ford took the window stickers offline 2 plus years ago...I am not sure you can get a current window sticker for an unsold vehicle. You might can get the dealer to print you one.
  #989
Old 02-18-2019, 11:09 AM
ILBCNUL8R
If you can't get your dealer to print one for you, there is an option to purchase a brand new official Ford window sticker for $25 available at this link
  #990
Old 02-18-2019, 07:00 PM
dkeyt7
dkeyt7 is offline
Belt reminder
Anyone have code to cancel belt reminder? I didn't see it in the spreadsheet.
Quick Reply: FORScan and As-Built Data
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
