FORScan and As-Built Data
#781
#784
Here is mine, didn’t update for at but you can see the blocks: I have heated/cooled seats that are controlled via fmt as well
apim
;Block 1
7D0-01-01 8221 9003 E2F1
7D0-01-02 0401 4200 0223
;Block 2
7D0-02-01 5553 0103 0086
7D0-02-02 0201 0000 00DE
7D0-02-03 0000 DC
;Block 3
7D0-03-01 2C54 5203 00B0
;Block 4
7D0-04-01 0003 0500 00E4
7D0-04-02 0001 DE
HVAC
;Block 1
733-01-01 0024 0000 0060
733-01-02 0000 0000 3D
;Block 2
733-02-01 3146 5438 5797
733-02-02 3342 5434 4782
733-02-03 4543 3938 3068
733-02-04 3838 B0
;Block 3
733-03-01 3000 0070 DE
;Block 4
733-04-01 3000 0070 DF
;Block 5
733-05-01 3000 0070 E0
;Block 6
733-06-01 3000 0070 E1
;Block 7
733-07-01 3000 0088 FA
apim
;Block 1
;Block 2
7D0-02-03 0000 DC
;Block 3
;Block 4
7D0-04-02 0001 DE
HVAC
;Block 1
;Block 2
733-02-04 3838 B0
;Block 3
;Block 4
;Block 5
;Block 6
;Block 7
#785
I have
7D0-01-01 XXXX XXXX E0XX for No Seat temp control
7D0-01-01 XXXX XXXX E2XX for Heated/Cooled
7D0-01-01 XXXX XXXX E4XX for Heat Steering Wheel
7D0-01-01 XXXX XXXX E6XX for Heated/Cooled - Heated Steering Wheel
if you put an "A" in that block , you get rear controls w/ H/C seats enabled, but that's a setting from my '15 Expedition. You basically add 8 to the values above in hex.
Additionally, you have to enable the climate quadrant
7D0-04-01 XXXX XXX0 XXXX for Climate quadrant enable (1 for disable)
#786
#787
#788
#789
Is this a good price? Or can you recommend a better place to purchase from?
https://www.ebay.ca/itm/ScanTool-426...YAAOSw5VtaOClI
Also, do I need the licenced version to change TPMS & Tire Size settings? Or does the free desktop verison of Forscan work?
#790
Not sure what Canadian prices are sitting at, for the OBDLink $80USD is an average price. Amazon is a popular place for purchase.
You will need an extended license to WRITE changes to the truck. The extended license is free after registration.
FORScan forum ? View topic - Standard and Extended licenses for Windows
#791
#793
https://www.ford-trucks.com/forums/1...l#post16763381
Somebody hasn't read the first few posts in this thread yet.
#794
#795
You can enable with FORScan. You will need to turn on remote start in the BCM. Check the spreadsheet link on the first page of this thread.
