FORScan and As-Built Data
#736
Depends on your trim level. The 4” LCD full color productivity screen is in the dash between the tach and speedo. If you enable the option, the outside temp appears in the upper right corner.
#737
#740
There is a link on the last line of the tire size area ABCD. It is to a tire size converter page. I have seen where people have created sizes to accomplish accuracy. Keep in mind you will most likely set a P160A code. This code is set by a difference in BCM vs PCM that we can't write to yet.
It will take some patience but you can get it perfect.
I have found that on my 16 the speedo needle is slow no matter what I do.
Hope this helps.
Keith
Hope this helps.
Keith
#743
works for me, I have all the items I need to update stuff, will set gear ratio and tire size with programmer back to no change and update with forscan afterwards.
Now if we could just permanently disable traction control/stability control...
#744
#745
#746
#747
#748
Hey guys,
Just bought my first truck the Saturday after Thanksgiving. It is a '15 F-250 6.7L CC SB 4x4 XLT. Love the truck and am planning on doing some of the Forscan mods as soon as I get back in town later this week. I have an OBD bluetooth adapter that should be waiting for me when I get back. I have uploaded my As Built file (both PDF and .ab) as well as my window sticker. I have read through this whole thread and saw that the Ford window sticker site wasn't expected to come back online. I was able to get to it the first week of Dec and get mine. I just checked and it now says "Please check back later. The window sticker has not yet been released for this vehicle". I must have been lucky. I do have the LCD productivity screen, trailer brake controller, HDC from the factory. An interesting note, I wanted to add the in-bed 7 pin connector for a 5th wheel so I purchased the factory kit from a dealer since I read that all US SD since 2012 are supposed to have the pigtails for the factory kit to plug into. After searching everywhere under the truck where they are supposed to be and then taking it to the local dealer, I found I have what the Parts manager calls a "mis-build". I have the taillight harness that is meant to be installed on trucks intended to be sold in Mexico and that harness does not have the 5th Wheel pigtails or the rear camera connectors.
I have created an account on ETIC but I am not sure what file I am supposed to get so I can upload it here.
As others have stated on here, thanks to those who have contributed a ton of time to get this stuff figured out. Looking forward to making some mods.
Troy
Troy
#749
Hey guys,
Just bought my first truck the Saturday after Thanksgiving. It is a '15 F-250 6.7L CC SB 4x4 XLT. An interesting note, I wanted to add the in-bed 7 pin connector for a 5th wheel so I purchased the factory kit from a dealer since I read that all US SD since 2012 are supposed to have the pigtails for the factory kit to plug into. After searching everywhere under the truck where they are supposed to be and then taking it to the local dealer, I found I have what the Parts manager calls a "mis-build". I have the taillight harness that is meant to be installed on trucks intended to be sold in Mexico and that harness does not have the 5th Wheel pigtails or the rear camera connectors.
Troy
Troy
I would think if you had the 7 pin at the bumper you would also have the harness to add the one in the bed also. Without research, not sure what it would take to add it.
HTH
#750
Look on the left rear side of your truck. Next to where the receiver hitch mounts to the frame. If your truck has the harness, there will be a wiring harness with 2 plugs and caps to plug your in bed 7 pin plug. Hopefully you have the harness.
HTH
HTH
It would have been nice but I went ahead and ordered the T aftermarket Harness that plugs into the 7 Pin connector from the bumper and runs up to the in-bed connector.
