FORScan and As-Built Data - Page 5 - Ford Truck Enthusiasts Forums
Old 12-10-2016, 05:44 PM
Trash Hauler
Trash Hauler is online now
Trash Hauler is gaining momentum as a positive member of FTE.Trash Hauler is gaining momentum as a positive member of FTE.
Originally Posted by blkout50 View Post
720-01-01 EA21 BA82 7FEF, OCR trucks
726-03-01 0201 0000 34, OCR trucks
720-01-01 EA21 BA83 FF70, My truck
726-03-01 0201 0001 35, My truck
My truck didn't like the 726-03-01 and would not accept those values from the OCR trucks.
Here is what it did take;
726-03-01 0101 0000 33
So far no DTC's...
My truck is
726-03-01 0101 0001 34
It did accept the numbers from the OCR truck (0201 0000) but it reset to 0101 0000 and changed me from a 4 door truck to 2 door (in BdyCM module)
0201 0001 is accepted but resets to 0101 0001
Mike, please see if your truck changed from 4 to 2 door. If so, this can be added to the spreadsheet.
726-03-01 xxxx xxx0 is 2 door
726-03-01 xxxx xxx1 is 4 door
I could not tell what the difference between 0201 and 0101 was because after it wrote 0201 it would reset to 0101.
Bob
  #62
Old 12-10-2016, 05:46 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
ZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud ofZooDad has much to be proud of
swarf-rat,
not sure about the mileage, but the dte can be tweaked by adjusting the fuel tank size, and tire size can be adjusted.
Im doing an experiment with mine right now. miles to empty was 5. Fuel % on TP was 0.0% flashing. I put exactly 5 gallons in, i'm up to 12.5% now. I should be at 7.7%. (I have a Titan 65 gallon tank). I will be filling up tomorrow. I don't normally run this low, but figured to try this since I was. It will give me an idea of what the "safety factor" is.
Keith
  #63
Old 12-10-2016, 07:58 PM
blkout50
blkout50 is offline
blkout50 has a good reputation on FTE.blkout50 has a good reputation on FTE.
Originally Posted by Trash Hauler View Post
My truck is
Bob
Bob,
Just checked and mine changed to 2 door also. Nice observation, I will update the spreadsheet with your find. Mine is also "stuck" on 0101 and I am unable to get it back to 0201. One thing i just now noticed is that 2 door extended cab is also treated as a 4 door (xxx1). I am using a 2 door extended cab without OCR for AB file comparisons. That tripped me up when I first noticed 726-03-01
My DPF is still at 95% so I have not seen the any change in my DPF screen. Good news is that I no longer have a DTC.
  #64
Old 12-11-2016, 05:35 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Did a bunch of playing around today with IDS and FORScan.
**Warning if you change IPC settings with IDS you will loose any saved trailer data info. How do I know ?
Working with blkout50 to find the OCR.
Keith
  #65
Old 12-11-2016, 05:43 PM
Just Strokin
Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Keith
I found this out also last year.
  #66
Old 12-12-2016, 04:01 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Busy day
So I got to playing around with IDS and FORScan yesterday.
I located and confirmed axle ratios and tire sizes.
I have updated the spreadsheet with this info.
HUGE shout out to F150Forum member Spart for his awesome WORK and developng his
Tire Size Conversion Sheet. With this info you can custom set for your truck for the most accurate speed / ODO. No more settling for close enough.
The guys over there have been very helpful helping us locate things in our trucks. I think the 17 guys would benefit the most as they most likely share more of the codes then we do.
Still chasing down OCR. I located a reference using IDS that references Diesel Particulate Filter Regen Request. But I think it is only half of the equation. I have a couple inquiries out.
I will keep you updated.
Keith
  #67
Old 12-12-2016, 08:29 PM
blkout50
blkout50 is offline
AWESOME find Keith!!
  #68
Old 12-12-2016, 11:32 PM
blkout50
blkout50 is offline
We haven't found the settings for the OCR... yet, but did find out how to turn on the Compass on the Info Center screen.
720-01-01 xxxx xxxx Exxx, DPF Screen, (Disable)
720-01-01 xxxx xxxx Fxxx, DPF Screen, (Enable)
720-01-01 xxxx xxxx 6xxx, DPF Screen, (Disable) / Compass, (Enable)
720-01-01 xxxx xxxx 7xxx, DPF Screen, (Enable) / Compass, (Enable)
Mike
  #69
Old 12-12-2016, 11:39 PM
4df150's Avatar
4df150
4df150 is offline
4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future4df150 has a brilliant future
Keith - uploaded my as built to your google. 2013 f250 Lariat, Crew cab, short bed, 6.7 diesel, 4x4, Nav, MFT, 5th wheel & gooseneck package, Bluejean Met., 20" wheels & tires, 3.55 e-lock.
I'm trying to fine a copy of my window sticker for you.
  #70
Old 12-13-2016, 04:30 AM
Just Strokin
Mike
Great work Mike....I know some with the 2013 and up trucks will be happy with this.
I sent you a PM about a vendor,, CircuitBoardMedics, that have done some productivity screen updates. You might inquire with them about the OCR.
  #71
Old 12-13-2016, 08:39 AM
blkout50
blkout50 is offline
Thank you Larry!! And thanks for the link, I will follow up.
Mike
  #72
Old 12-13-2016, 09:39 AM
ZooDad's Avatar
ZooDad
ZooDad is offline
Mike
Great find Mike. Thanks for the update.
  #73
Old 12-13-2016, 09:40 AM
ZooDad's Avatar
ZooDad
ZooDad is offline
Thanks for the upload. I will grab the data and run etis.
Keith
  #74
Old 12-13-2016, 05:33 PM
blkout50
blkout50 is offline
Thanks Keith!
  #75
Old 12-13-2016, 07:51 PM
4df150's Avatar
4df150
4df150 is offline
Keith
Keith - See attached for my window sticker. Hope it helps.
File Type: pdf
Quick Reply: FORScan and As-Built Data
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
