FORScan and As-Built Data
#706
you will need to tie into the running light circuit, such as clearance lights.
#707
#710
#711
#712
Anyone find out if this I’d doable to permanently disable stability and traction controls? I was all excited by the HDC and TBC until I realized it was trailer brake control
#713
You will also have to program the HSWM itself.
Here is what we have in regards to the settings.
(HSWM)
714-01-01 0A00 0000 **
714-01-02 0238 3838 **
In your APIM settings if you PM me your 7D0-01-01 data I can fill it in, but in the mean time.
7D0-01 xxxx xxxx E0** No Seat Temp Control
7D0-01 xxxx xxxx E2** Heated/Cooled Seats
7D0-01 xxxx xxxx E4** Heated Steering Wheel
7D0-01 xxxx xxxx E6** Heated/Cooled Seats/Heated Steering Wheel
I will be watching closely as this is something I am interested in doing.
PM me if you have any FORScan questions.
Keith
(HSWM)
Keith
https://drive.google.com/open?id=1zZ...chglH5Zr8G_zku
#714
Thanks Larry and Mike, oddly I don't recall ever not having the compass in the upper right hand corner of the productivity screen, before or after the tune. (Or I just didn't notice it not being there before).
I do not have the fourth dot, and my third dot is blank just like your first picture Larry.
I appreciate all the help. I am deleting my truck this week, you don't have to spend too much time attempting to sort it out. I think this must be related to the tuner. I will be flashing it back to stock before I load the delete tune probably on Wednesday if the weather is nice. I can check and see if I can add it then.
720-01-02 xxCx xxxx xxxx Temperature, Productivity Screen, (Disable)
720-01-02 xxEx xxxx xxxx Temperature, Productivity Screen, (Enable)
https://www.ford-trucks.com/forums/1...l#post16801017
#715
2016 F350 Lariat Heated Steering wheel Successfully Added - After owning my Truck for year now and spending hours researching this I was able to piece enough information together to successfully do this Mod, I just did it today and it's great! I also put together a little PDF How to guide for anyone else that wants to do this. Hope it helps someone
Great write up, saved for future info.
#716
#717
#718
REMOTE START (If Equipped)
The remote start feature allows you to
pre-condition the interior of your vehicle.
The climate control system works to
achieve comfort according to your previous
settings.
Note: You cannot adjust the system during
remote start operation.
Turn the ignition on to return the system
to its previous settings. You can now make
adjustments normally, but you need to turn
certain vehicle-dependent features back
on, such as:
• Heated seats.
• Cooled seats.
• Heated steering wheel.
• Heated mirrors.
• Heated rear window.
The automatic settings does turn on the seats for heating and cooling but not the steering wheel in the winter when the following conditions are met and you have "Auto" selected in the climate control panel.
Automatic Settings
In hot weather, the system is set to 72°F
(22°C). The cooled seats are set to high
(if available, and selected to AUTO in the
information display).
In moderate weather, the system either
heats or cools (based on previous
settings). The rear defroster, heated
mirrors and heated seats do not
automatically turn on.
In cold weather, the system is set to 72°F
(22°C). The heated seats are set to high
information display). The rear defroster
and heated mirrors automatically turn on.
#720
Where in the information display is the auto setting? I don't recall seeing it. I do have the auto physical button on the dash.
