FORScan and As-Built Data
#691
Originally Posted by Betaracer
Thanks.
Another thing I was playing around with was tire size and axle ratio in the change by clicking in the preset option section. I got a few DTCs so I changed back. Do the DTCs clear with some distance traveled after the computer learns new parameters?
#692
They don't clear with time or mileage. You will get DTCs without a light if you change the tire size in the BCM only. I believe the DTCs are usually caused by a mismatch of sizes between the ECM/TCM and BCM. At this time I don't think ForScan can access the ECM/TCM to change the tire size.
#695
There is a process that requires a relay wired to an up-fitter switch. Keeps the Advance Trac off as well as allows the ELD to stay engaged. Not sure of the specific wiring. Guy hasn't responded to me so I can post up the wiring and diagram.
#696
https://www.spediesel.com/products/s...-lock-diff-kit
Be careful that you don't run the battery down. I haven't had personal experience, just read about it somewhere. Might depend on how it's connected.
#697
I installed running lights above my running boards and have them powered by the plugs for the power steps. Can the programming be changed so the power step plugs can be changed to the parking light and stay on when the lights are on. If not I'll have to find the parking light wire and tap it.
#698
#699
hey boys! been searching for days and finally decided to join the site also. has anyone figured out on forscan to disable courtesy lights?! when you open the door id like the interior to stay on but not the entire outside of my truck light up. i saw the spread sheet, either i cant figure it out or its right in front of my and im confused lol. should be in "as built" files?
#700
That is the plugs I used, sorry for the confusion. I also want the lights to be on with the parking lights at night. That's way the question about reprograming the BCM.
#701
Added Navi. I have had success with Sirus delete, adding HDC but Navi has me perplexed. Nav works but when I scan with FORScan I get a DTC.
I have cleared the DTC a couple times but it comes back.
My As-Built 7D0-01-02 is: 0001 4200 021F
As per the tutorial I changed the first two numbers in the first field from 00 to 04.
Now I get a DTC: Code B1215 - External Memory Card
Should the FORScan be run the the Map Card removed to not get the DTC?
If that is the case why is the Maps throwing a code? It is a Ford A8 SYNC card.
Thank you.
Thank you.
#703
