FORScan and As-Built Data
#616
#618
#620
#621
As an aside, has anyone begun to look into the ACM code to find out about fixed and variable unclipped line level outputs. The guys over in the F150 forums have figured out the 2015+ (2017 SD) ACM's, but I don't trust that data to transfer to our 11-16's.
https://docs.google.com/spreadsheets...#gid=338817466
(check under ACM tab)
I would like to figure it out myself, but alas I have no access to an oscilloscope to check outputs for each change in code.
#622
I have the download, but I cant make anything of itl Here is a copy of what I get
LABEL="724-05-01"><CODE>0320</CODE><CODE>0320</CODE><CODE>77</CODE></DATA><DATA LABEL="724-06-01"><CODE>003C</CODE><CODE>003C</CODE><CODE>AA</CODE></DATA><DATA LABEL="724-07-01"><CODE>003C</CODE><CODE>FFFF</CODE><CODE>6D</CODE></DATA><DATA LABEL="724-08-01"><CODE>FFFF</CODE><CODE>FFFF</CODE><CODE>30</CODE></DATA><DATA LABEL="724-09-01"><CODE>FFFF</CODE><CODE>FFFF</CODE><CODE>31</CODE></DATA><DATA LABEL="726-01-01"><CODE>0000</CODE><CODE>002F</CODE><CODE /></DATA><DATA LABEL="726-02-01"><CODE>0A3A</CODE><CODE /><CODE /></DATA><DATA
#623
you actually look at the end of the line for the 724-01-01 and then the beginning of the next line for the values. There are NO check sums in the AB data. The ECU will apply the check sums for you.
Examples
724-06-01 003C AA
726-01-01 0000 002F
Examples
724-06-01 003C AA
726-01-01 0000 002F
#624
#627
#629
#630
Info please
Good evening Gentleman,
I have been following this thread closely and read every post up to page 25...
I've tried the Bambi Mode and the Fogs on with highbeams and I can confirm neither worked on my 2012. The bambi mode only made my DTE read 999.
So my question is, Has anyone made successful mods to the 2012?
I love this ForScan software and I am trying to enable some useful features on mine but so far the only thing I've been able to do was change my tire size, which somewhat corrected my speedo...
2012 F250 Lariat Ultimate crew, 176" WB, Powerstroke.
Thanks
(BTW: ignore my username, Its my old truck and I cant figure out how to change it.)
Thanks
