NOS fenders - Ford Truck Enthusiasts Forums
NOS fenders
Old 11-29-2016, 08:40 PM
brad1979's Avatar
brad1979
brad1979 is offline
brad1979 is starting off with a positive reputation.
NOS fenders
I found a guy selling what he says are factory NOS front fenders (both sides) for what seems like a reasonable price. Says he worked for a Ford dealer in the 90's and has had them since. How do I determine if they are the real deal? Will there be part numbers or stampings to look for? The NOS bed sides came in the original boxes and have Ford stampings but I seem to recall they were made overseas (might be wrong). I have aftermarket replacement fenders (overseas) already, not installed yet. Does anyone have any experience with NOS or aftermarket front fenders that could tell me if there is much difference, or if NOS is worth it? Thanks.
Old 11-29-2016, 08:47 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Don't know much about NOS fender numbers and markings. But I can guarentee their quality and thickness will be 100% better than the aftermarket fenders. The aftermarket fenders are ok and do the job, but if you are picky only the factory ones will ever do.
Old 11-29-2016, 11:02 PM
SCFlareside's Avatar
SCFlareside
SCFlareside is offline
SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.
We used aftermarket on our trucks but getting them to fit correctly is a bit of work - reamer has some good advice on fitting them in a thread that I'll have to dig up.
I swear that mine still very slightly open up the door / fender gap when my back is turned but I can't be sure
Old 11-29-2016, 11:04 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Anything produced by Ford should have FORD written all over it. Look on the mounting flanges where the top of the fender is bolted to the body; at a minimum there should be at least one Ford oval insignia stamped into it and some sort of engineering ID, probably something like E1TA BA or somesuch (that's an example).
Old 11-30-2016, 08:32 AM
brad1979's Avatar
brad1979
brad1979 is offline
Good info. Thanks. Now I just have to go look at them, and of course the guy has them way out of town. I'll post an update if they ever materialize.
Old 11-30-2016, 08:56 AM
reamer's Avatar
reamer
reamer is offline
reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.
Yep, should be a Ford Oval on the upper - inner lip where it's welded to the inner skin.
SC, ya still have not fought the fender alignment?
Old 11-30-2016, 11:13 AM
1986F150six
1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Something like this, Chris? Look at the last two photos. NOS 1980-1986 GENUINE FORD TRUCK BRONCO RIGHT FRONT FENDER F150 F250 OEM | eBay
Old 11-30-2016, 11:16 AM
brad1979's Avatar
brad1979
brad1979 is offline
Now I know what to look for. Thanks.
Old 11-30-2016, 04:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
You sure about that?
When Ford updates a part number, dealers have one year to return the original part number for credit, otherwise they're STUCK with it.
E1TZ-16005-B (replaced E0TZ-16005-A) Right & E1TZ-16006-B (replaced E0TZ-16006-A) Left .. Front Fenders: 1980/86 F100/350 & Bronco.
So, it's possible that these fenders have the original 1980 part numbers, why the seller acquired them in 1990's, probably for cheap...because the dealer was STUCK with them.
Old 11-30-2016, 04:56 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
WhatsAChevy? is offline
WhatsAChevy? has a great reputation on FTE.WhatsAChevy? has a great reputation on FTE.WhatsAChevy? has a great reputation on FTE.WhatsAChevy? has a great reputation on FTE.WhatsAChevy? has a great reputation on FTE.
Because the Parts Manager wasn't on top of their game. I inherited no-turn, obsolete, in the red inventories at 3 different dealers for that very reason.
Old 11-30-2016, 05:00 PM
brad1979's Avatar
brad1979
brad1979 is offline
Hi Bill, I hoped you would join us. Specifically I was referring to where a part number and/or Ford stamping would be on a NOS fender (from ad photo). So the next question, is there any physical difference between E0TZ and E1TZ? If the fenders are legit and if they have part numbers, would the E0TZ fit my '81? Apparently the guy rebuilt a truck or 2 back in the day and had these leftover from a project that didn't get done.
Old 11-30-2016, 05:12 PM
NumberDummy
Is there any physical difference between E0TZ and E1TZ?
I couldn't say, haven't seen any of these fenders since George H.W. Bush was prez.
Of course, since E1TZ replaced EOTZ
FoMoCo is in-famous for replacing/updating 10's of 1000's of part numbers EVERY YEAR!
WhatsAChevy: Ever do a PIPP?
1966/86: I bought out over 300 west coast FoMoCo dealers stocks of obsolete parts because the P/M's never did a PIPP or a POPP.
The biggest haul was El Monte Ford. While the manager was alive, he never returned anything...wouldn't sell anything either.
When he died and the owner found out what he had done, he said GET RID of this crap! It took two semi trailers to haul the parts away.
Old 11-30-2016, 05:22 PM
brad1979's Avatar
brad1979
brad1979 is offline
Thanks Bill!
Old 11-30-2016, 05:56 PM
WhatsAChevy?
I certainly have...this strikes a nerve with me. One of the "few" dealer principals that i worked for was a hoarder because his father started the dealership in 1932 and collected one from every model year in a warehouse. That warehouse caught fire. He hoarded everything since in memory of his father. Parts, advertising, apparel, you name it. The Parts Dept. had a 2 foot winding path through it with parts everywhere. On the floor, shelves and in the rafters. I was charged with sorting, cataloging and the dispensing of a half-million dollar parts inventory. I get it.
Old 11-30-2016, 06:02 PM
NumberDummy
The thing is, doing a PIPP is time consuming and dealers, especially in small towns, didn't have the manpower.
So, they had to do it on off hours, evenings and weekends when the dealers parts departments were closed.
Getting the dealer principles to pay for those off hours could be daunting, so many P/M's didn't bother.
btw: I see you have a DeSoto with "Clunk-O-Matic." I owned a '49 DeSoto in the early 1970's and knew how to drive it, cuz I learned to drive in 1952 on a '47 Chisler with "Clunk-O-Matic."
Quick Reply: NOS fenders
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
