Coolant Filter Brass Fittings
I've got a Baldwin coolant filter mount that I'm about to put in my 7.3. The last thing I need to get ahold of are the barb fittings. I'm not sure if there's anything I need to look out for in terms of temperature rating or anything else. For example, these appear to be dirt cheap but don't say anything about what temp they're rated to:
https://www.zoro.com/value-brand-hos...19/i/G0667213/
For all the threads about coolant filters that I've found here, none that I can find go into detail about where they got the fittings, quality of the fittings, etc.
Those brass fittings should work just fine. Your engine will not develop enough heat to damage them.
How ever if you are in Kali land, you could get Cancer or a Birth defect using this product.
*1 : California Proposition 65 : This product contains a chemical known to the State of California to cause birth defects or other reproductive harm.
*2 : California Proposition 65 : This product contains a chemical known to the State of California to cause cancer.
Every thing in Kaliforne is bad.
Charlie
Charlie
Charlie
Charlie
the only thing bad in cali is the 3 L's.
legislation, leftist, and little *******
to the OP,
stainless, aluminum, or brass.
you wont have an issue. you just need to know the pipe thread size.
Yeah I know all to well, lived there 70 yrs, finally got the heck out.
Almost too afraid to drive back over there with all the craziness.
Charlie
