2012 wheel hub bearing - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 11-27-2016, 07:41 PM
fishbones182's Avatar
fishbones182
fishbones182 is offline
fishbones182 is gaining momentum as a positive member of FTE.fishbones182 is gaining momentum as a positive member of FTE.
Thinking of replacing front wheel hub bearing assemblies. They are not bad to my knowledge. But thinking of doing a big 4 link lift so I want to start fresh. What brands have you guys used? Does the needle bearings come in the unit or are they a separate bearing? The bearing units do seem kind of pricey I was quoted 750 for a pair at my local dealer.
Old 11-27-2016, 07:57 PM
brickman
brickman is offline
brickman is gaining momentum as a positive member of FTE.brickman is gaining momentum as a positive member of FTE.
Only advice I can give is don't go cheap on em. I made that mistake once and only got a year out of a cheap set
Old 11-27-2016, 11:02 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
You can get high quality parts from other sources resides a dealer, I've always found the dealers to be over priced.
Denny
Old 11-28-2016, 06:27 AM
Chuck's First Ford
Chuck's First Ford is offline
Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.
I got motorcraft parts from rockauto.com
they carry many brands of parts.
best of luck in your project.
Wrench/work Safe.
Old 11-28-2016, 05:33 PM
fishbones182
Thanks for the input. I'll check out rock auto too. I'm used to wrenching on cars/trucks I have a 4 bay shop with a lift. After doing some more reading I think I'll opt for the motor craft posts on the wheel hub assy. Here's a pic of my other superduty I built but she's on 5 ton axles. I want a streetable toy now lol.
DavenTn
04-03-2018 09:36 AM
Rider15
1999 to 2016 Super Duty
03-09-2017 08:20 AM
Skydivelout
28
02-18-2017 06:37 AM
unlucky2.1_7.3PSD
06-23-2016 09:39 AM
BPSgt54
2009 - 2014 F150
03-23-2016 11:11 PM
Quick Reply: 2012 wheel hub bearing
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
