Coyote Swap
Coyote Swap
Has anyone swapped in a coyote in place of the 390...Whats all needed minus the engine, transmission, harness....can you keep the I beams and front cross member.
Kicking around the idea of jerking out my 428CJ in my 69 and putting in coyote...I have DJM drop I-Beams and don't really want to do the crown vic front clip.
Any and all ideas
Scott
Any and all ideas
Scott
Coyote
The Coyote package comes without the left manifold, you will need one from a 2011 Mustang. If you have power steering you will need an adapter kit that mounts the steering pump depending on which kit you use may require machine work on the timing cover. An external fuel pump and regulator will be needed.
I am currently doing the installation with the C V set up. Figure on a new driveshaft. If you are using a manual transmission you will not need a flywheel. I estimate that by the time I am rolling I will have knocked the hell out of 10k.
2011 Mustang 5.0L left side exhaust manifold is part number BR3Z9431A. Replaced by BR3Z9431C.
Coyote #
When I was ordering, the dealer (Lamarque Ford) parts manager said that the 2016 model was the only #. This is the basic 420 hp model. Of course there are a couple of high $ models available. The control kit is the same as 2014.
M-6007-M50A. Engine $7,026.50
M-6017-M504V.Control $1,554.85
Power by the hour alternator swap kit $749.99 The cheapest one I could find.
BR3Z-10346 B Alternator $350.87. The only alternator that can be used.
BR3Z-9448-A Manifold $170.00
Driveshaft $350.00
I still have to get the transmission rebuilt and need a stand alone control kit.
Driveshaft $350.00
Driveshaft $350.00
Driveshaft $350.00
Type: Attachments
Attachments: Section_11292016_1532.pdf 121.1 kb
5.0L COYOTE 435 HP MUSTANG CRATE ENGINE .emissionsLabel { color: #333; } .emissionsLabel:hover { text-decoration: none; color: #333 } .multi-img-col { position: relative; z-index: 1; }
M-6007-M50A
Retail
$7,875.00
Sold in Units of
Each (1)
Instruction Sheet
Not Available
ATTENTION:
This part is intended as a replacement part for use only in the application(s) identified in the product description. Installation of this part in a vehicle for which it is not intended may violate U.S. and Canadian laws and regulations related to motor vehicle emissions.
The Ford Performance all-aluminum 2015 5.0L Coyote crate engine is a modern 5.0L 32-valve DOHC V-8 that uses advanced features like Twin Independent Variable Camshaft Timing (Ti-VCT) to deliver 435 horsepower @ 6500 rpm and 400 ft.-lb.+ of torque @ 4250 rpm (with premium fuel). The lightweight aluminum cylinder block features cross-bolted main bearing caps and thick main bearing bulkheads for bottom-end strength, optimized oil drainback and windage control to improve high-rpm performance.
M-6007-M50A Coyote Crate Engine Technical Reference Guide
Part Type
Engine: Complete Engines
Packaged Dimensions
36.5" x 44.5" x 36
Packaged Weight
549 lb(s)
UPC Code
756122002087
Country of Origin
Canada
M-6007-M50A
Retail
$7,875.00
Sold in Units of
Each (1)
Instruction Sheet
Not Available
- 435 horsepower 400 ft.-lb.+ of torque
- 11.0:1 Compression ratio
- Hypereutectic aluminum pistons
- Forged steel connecting rods
- Forged steel crankshaft
- Aluminum block
- 8qt capacity oil pan
- Tuned composite intake manifold provides efficient air delivery and weight savings
- 80 mm single bore "drive by wire" throttlebody with variable runner control
- Aluminum cylinder heads, DOHC, four valves per cylinder, Variable intake and exhaust camshaft timing
- Mustang GT 409 stainless-steel tubular exhaust manifold on the RIGHT SIDE ONLY
- Includes manual transmission engine harness and flywheel
- Vehicle harness and PCM not included
- Use Ford Performance's NEW wiring, PCM and installation kit M-6017-504V designed for street rod/project car installation.
- Does not include alternator, for alternator kit see M-8600-M50BALT
- Engine mount bosses and bell housing mount pattern common to 4.6L modular engines
- 5.0L Mustang engine cover kit available, see M-9680-M50A
- Photo and specs may vary.
- Engine weight: 444 lbs.
Part Type
Packaged Dimensions
36.5" x 44.5" x 36
Packaged Weight
549 lb(s)
UPC Code
756122002087
Country of Origin
Canada
jjpeach
03-05-2015 07:43 PM
1978fordf250
Offroad & 4x4
23
09-13-2010 04:52 PM
