1997 F150 4x4,1999 tranny 2wd conversion ?
I am looking at a 1997 4x4 F150 with a bad transmission, how much work is it to put a 1999 2 wd Auto in it out of a 1999 F150.
I imagine you are better off rebuilding the stock 1997 and keeping the 4x4 but this is a work truck so I do not care ... Thanks..... and happy holidays.
You would need to decide how much work your willing to put into the conversion and is it worth it.
1. Remove the front drive shaft.
2. Remove the rear drive shaft.
3. Remove the 4x4 trans.
4. Look at the harness and plugs for compatibility. You will not use the transfer case motor plug.
5. Drive shaft length to fit your truck's wheel base.
6. Speed sensor needs.
7. Issues to be solved as they come up.
Best to find a doner truck so all parts you need are available.
Good luck.
Good luck.
the newer the truck , the better. That being said, not a major difference in reliability between 97 and 99..... would have more to do with the maintenance done to the truck in the last 20 years... how many miles.. what suspension / body parts are worn out.
After the transmission swap, you leave off the front drive shaft. Leave the front pumpkin in place with the axle half shafts. They hold the wheel hub/ bearings together. Leave off the vacuum operated hoses to the axle so the front end does not engage.
I believe that the shafts would likely have different dimensions between the RWD and 4x4 models. I don't know if the rear ends are different, and if that would play into it at all.
Arrow201
03-29-2006 04:44 PM
dorymate
10-04-2004 03:30 PM
