Ford Racing Rear Cover
So I was looking for options for a new rear cover without needing to get a payment plan, and I'm posting here because there is NO info on the net. Since I just rebuilt my rear with 3.73's and a Detroit Truetrac it was time to change the gear lube anyways. I frequently tow a 5000# boat and want my rear nice and cool when it's working. Using a infrared temp gun on similar days it is a solid 15* cooler.
I was looking at the cover that came on the 2013 Ford Mustang Shelby GT with the Track Pack option. The ones that come as a kit with the bolts M-4033-KA are like $170, without the bolts as a replacement part DR3Z-4033-B you can find the for $69.
So I read in the description on ford racing that this would not work for trucks. I did find a post from a guy who put one on a ranger. He found that the tone ring was the problem and had the cover ground to fit. The only other post I could find was for a guy with a Bronco, but he gave up. Since i have a grinder that was all it took to sell me on the idea, and so I waited for my amazon box to arrive.
Although they say it's not needed, my local NAPA had a gasket for it in stock.
I figured my local Tractor Supply would have the grade 8 bolts. I like to use flat and lock washers, so the length needed is 1-1/4".
The only other thing you will need is a metric bolt for the breather on the new cover, sorry I don't know the size. I used a banjo bolt with a copper washer from a trailer brake. On a similar note there is a small screw holding a plate over the vent hole on the cover, I took that off.
So all in all the cover is a nice piece.
I like that it has finns on the inside. Also the vent cover is for Mustang applications.
Here the fin that hits the tone ring has been removed(3rd from the right). I used a dremmel with a cut-off wheel and finished with an angle grinder. I had thought the angle grinder would eat it up but no. The fin is about 3/8" thick and it was way too slow.
next I removed the vent plate and washed down with brake clean. Goop, gasket, bolts to 25'# and fill.In the end it looks like this. The bolts I got were 1-1/2" and were too long. I will get this resolved soon but it holds oil just fine.
and this is what got removed from the cover
No modifications necessary. Hardware and gasket included
https://www.amazon.com/Premium-Quali.../dp/B00D0X1MUQ
Towing in the summer I would see 160*-185* at the pinion on longer trips, so increased cooling was the goal. If the next step for the truck was NOS or forced induction then that might be my choice.
It does enough to make Ford think it was necessary on the Mustang. All of the new HD trucks come with finned aluminum covers too.
He said the bolts he bought were 1/2" too long and that he would fix it. For now, the bolts as spacers are fine.
Nice job! I wish I could find an aluminum one for my Super Duty that wont break my bank. I really like the fins on the inside, with all that surface area it should make a difference in the heat that gets "wicked" out.
Hey Fords4Me, The temps you were reading on your axle, where the temps taken after hauling or empty? I have one of the temp reading guns, I have been wanting to see just how hot my f350 got while towing the 5th wheel. Please let me know if and how the temp readings change with the new cover.
It looks great!
It looks great!
