KOEO-111, KOER- Cyl. 8 and 538 - Page 4 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
  #46
Old 11-18-2017, 01:12 PM
WhyFord WhyFord is offline
WhyFord is starting off with a positive reputation.
I took out and checked PCV grommet and elbow, they are both OK. But the two hoses are as hard as rock. So I replaced them together with a new PCV.
I vacuum checked brake booster and it holds very well and the hose is OK too.
I cleaned up the throttle body before and didn't find anything unusual.
I did find a coolant leak on the small hose goes into the throttle body. I think it's used to warm up cold air before it goes into the engine. I replaced it with a new hose.
After all these, the engine still runs rough!
I will replace distributor cap/rotor, flush fuel injectors with OTC Pro Inject-R Kleen next and report back. In the meantime, if you have other suggestions, please let me know.
1994 Ford F150 /4.9L , Problem jterrell 1987 - 1996 F150 & Larger F-Series Trucks 10 10-31-2017 06:55 PM
RE: Ford F150 Problems jterrell Ford Inline Six, 200, 250, 4.9L / 300 4 10-26-2017 10:22 AM
RE: 1994 Ford F150 / 4.9L Problem jterrell Ford Inline Six, 200, 250, 4.9L / 300 2 10-15-2017 08:11 PM
1996 5.8l shaking tomandheneryrock.bw Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 07-16-2017 04:25 PM
No start after attempting KOER read NinetyFiveF150 1987 - 1996 F150 & Larger F-Series Trucks 19 03-13-2017 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
