Safe way to lift 5th wheel?
So, are we in agreement that jacking the entire one side of a 5th wheel trailer is best done by one jack point under the u-bolts on one axle? By lifting up one axle, the other axle will drop and the entire side of the trailer will raise up enough to get cribbing under 2-3 points along the frame. Does this sound about right with the intentions of removing both axles and suspension at one time?
I am asking these questions so I know what to do when I go to replace everything under the new to us trailer we purchased.
When this first came up, I was responding as though changing a flat. What you are doing, I believe is basically getting the entire frame up in the air to you can take everything off, one side at a time.
I have a collection of jacks and can stack pieces of 2x10 or 2x12 so I can jack up the frame. I think you can also use leggos or wood and run the back wheel up so the front wheel comes off the ground. Then support the frame and jack up the rear.
When I put my TruTrack on I used both wood and multiple jacks on my fiver. I did leave my fiver hitched so it could not move around.
Steve
I see, looks like I got off track and thought this was a thread on getting all 4 wheels off the ground which relates to my plans. I apologize for the thread high jack, although maybe someone can learn something from it in the future.
Although, I guess I would need to have all 4 wheels off the ground and the trailer supported with 4 or 6 jack stands. This would allow easy access to everything below the frame of the trailer and make the job go much quicker.
I believe you are saying that if I am wanting to change the tire the base of the u-bolts is the best point to lift that tire off the ground. But, if we are wanting to get all 4 tires off the ground, raising the trailer by the frame is the right way to do it and then support the jacking points with stands/cribbing and leave the trailer connected to the tow vehicle for extra stability.
Does jacking the trailer up by the frame sound right for the situation of getting all 4 wheels off the ground?
I can't remember. I recall you are going to change to hydraulic brakes. Do you intend to do something more. If it is just changing the brakes, you might pm RV Puller and see what he did to get his Hitchhiker in the air.
If it is just the brakes, you could work one side at a time, which might be simply. If it were me and just brakes, that is what I would do.
Steve
Steve
The single concern I have in doing this is working each side up so it is somewhat level. I doubt there is a guide book for doing this. It is pretty common place with permanent setups at the lake and I do not think much thought goes into it. As always time and logical are the principle guides and multiple supports for safety.
Steve
Call me chicken little but I would have the frame cribbed front, rear and in the middle. I would not trust the landing jacks on anything that could possibly shift. He will be moving a lot of weight around installing and aligning those axles. Another 1/2 hour or so of installing extra cribbing could save a life time of sorrow. Just my 2 cents.
Steve
Bugzilla46310
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
20
09-15-2018 12:56 PM
