Part number for M/C?
Trying to shop economically(read: I'm cheap).
I'm converting my single res master cylinder to a dual. I ran across some info here that said I could use a master cylinder from '70 F100 with drum/drum and not have to change anything about the M/C. It already had the residual pressure check valves so I'd have to do nothing more than install it. But whenever I search for that year, the search results show what appear to be your typical disk/drum M/C. Could be a stock photo, but I don't know for sure. Anybody got a Ford part number I can search for?
Some websites are offering the M/C with metering, or proportioning valves. Are they necessary?
Thanks in advance.
Thanks in advance.
1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
All 1967 and later FoMoCo vehicles with dual master cylinders require a "brake pressure differential valve" that some people call a proportioning valve.
https://smile.amazon.com/Cardone-10-...3Aford%3Af-250
I searched for a 1969 F250. This one shows different reservoir sizes like I was asking about earlier. Is that consistent with what you would have found on a stock '69?
If this will work on my drum/drum setup, I'll probably just get this and save about $50(over buying the bracket/master cylinder combo).
yellodog
07-01-2015 09:20 PM
60RatRod
20
10-06-2007 09:13 PM
ivanribic
11-17-2004 11:05 PM
58 Model
04-10-2004 06:06 AM
