In need of Vacuum Switch and Vacuum Regulator Valve 6.9/7.3 IDI
Old 06-17-2018, 11:55 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
Originally Posted by Dieselamour
How much vacuum are we working with?
Are the ports switched?
What temperature does it switch?
What size threaded fitting?
typical vacuum drawn by the pump is over 19 inches for a good pump. once it falls below 18-19 inches you start having problems with shifting.
Old 06-17-2018, 12:46 PM
genscripter's Avatar
genscripter
genscripter is offline
I installed an old boost gauge on my dash, which coincidentally has vac pressure on the left side of the scale. I tee'd it into the vac system, because over the last 5 years of owning my IDI van, I've had 2 vac pumps fail on me in the worst possible places. Now, at least I know if the vacuum starts to degrade before I'm in some remote place of the world.
For the most part, my gauge reads around 25 in hg during regular use.
With the VRV, it is not temperature modified. It's a mechanical valve, which needs to make a gradient shift in vac from over 13inhg to 5inhg depending on throttle rotation.
I don't think the plastic threading is something logical like an NPT threading. I just modeled it in CATIA based on it's thread count, depth, and other helix measurements. I was able to simulate it in Assembly Design and verify it fit with the appropriate 3D constraints. So it should fit with EOM versions, and I can post pics once my high-grade plastic prototypes arrive.
Old 06-25-2018, 06:56 PM
Tugcountry's Avatar
Tugcountry
Tugcountry is offline
Originally Posted by georgehirvela
A private party says he has 8. going to get one today. FYI
hey man do you still have that contact for the VRVs?
Old 06-26-2018, 09:25 AM
Olds64's Avatar
Olds64
Olds64 is offline
Originally Posted by genscripter
I've been working on a VRV solution
That's awesome. Let us know how your prototype works.
I recall reading on-line that an IDI owner tried to modify a VRV from another diesel. I wonder if this one could be made to work?
Amazon Amazon
Old 09-13-2020, 05:11 PM
Richard Povilaitis's Avatar
Richard Povilaitis
Richard Povilaitis is offline
did this work on your truck
Old 09-13-2020, 05:12 PM
Richard Povilaitis
1986 vrv to run 1986 f350 c6 trans
Old 09-13-2020, 05:42 PM
lonewolf_'s Avatar
lonewolf_
lonewolf_ is offline
Scope Wizard
the GM VRV turns the opposite direction
I've used parts from the GM VRV to fix the Ford units.
it is possible to to change the configuration of the IP but sure is a PIA.... right now the options are use a Mechanical Modulator Valve that is controlled by a Cable, use the VRV that Genscripter makes or Modify your C6 to a Manual Shift where it doesn't use a Modulator and lastly use DRV101 electronic with a TPS.
ddaily726
04-16-2017 08:55 AM
Matt1966
03-21-2017 09:04 AM
tyler.dunn94
11-22-2016 01:17 AM
tyler.dunn94
11-21-2016 03:12 PM
frankyford
17
07-05-2009 01:42 PM
Quick Reply: In need of Vacuum Switch and Vacuum Regulator Valve 6.9/7.3 IDI
