Who knows where to buy?
Once again I turn to you guys for a bit of help. I have looked around every where and can't find replacement transmission cooler lines for our trucks. I have tried LMC, Bronco Graveyard, local parts stores, local salvage yard, even brokedown and called the local stealership. If memory serves I believe I saw a set for the 4WD on Bronco Graveyard, but alas I have a 2WD. I am hesitant to "patch" with fuel hose, I have never had any luck with that, always ends up failing and puking fluid. I am really not wanting to try bending line, I did that for my MF Tractor on the fuel lines and that was a pain in the ****. So who on here has my save the day solution. If you know a place please throw up a link. Or any other help would great.
Thanks in advance.
Thanks in advance.
Received 3,090 Likes
on
theredneckrussian
02-03-2013 02:56 PM
