2007 Ford F-150 4x4 Misfire
I am new to this. I just bout a 07 f150 4x4 with 69 thousand miles less than a month ago. Since then the transmission has been rebuild but come to find out a misfire will cause overdrive to act up, and it just recently started misfiring badly. It was throwing a code. 2 coils were replaced and still misfiring. It's not throwing a code anymore. no check engine light flashing or nothing. Pep boys is stumped and recommended to take it to a dealer. I am completely lost as to what this problem may be. Somebody please help
You've already been shafted by one stupid mechanic who can't differentiate between a (vehicle characteristic) 'misfire under light load' and a torque converter clutch problem. Don't do it again by taking it to a dealer. Most likely THEY will tell you that you need a new motor like so many have reported here.
Based on the limited information given here, I would bet 99% of the farm that you need to replace all eight spark plugs, COP Boots & springs (NOT COP's themselves), in a very careful, meticulous, clean mechanic like manner using only Motorcraft SP515 plugs.
Yes. It's missing on cylinders 1 and 7. Well stupid me I replaced 5 and 8 today. It did make a difference but still has a bad skip. So tomorrow I'll be back under the hood replacing 1 and 7 and that should fix it. But this weekend when I have more time I'm gonna replace the rest of them because once one goes they all pretty much go
Great!
My '07 is up not far from 58,xxx and I know it's a good idea to change them sooner rather than later. I bought the Lisle tool a few years ago about the same time we bought a '08 GT which has a 4.6-3v but it's only got about 30,xxx miles. Still .... good purchase I think.
Thank You .... I had not yet looked at a video for a simple reason .... my Verizon 4G network plan was limited in data .... but recently I swapped over to a new plan with a bunch more and suddenly I can check out a few videos .... and after looking at that video, I see how handy that Lisle tool really is.
Yes. It is the Lisle part# 65600 and you can rent it at a local auto parts store. Here is a video explaining how to use it.
https://www.youtube.com/watch?v=BSY9iBheBXI
I posted a thread on how I did it.
https://www.ford-trucks.com/forums/1...ug-change.html
The second time I changed the plugs was at 193,000 miles, followed the same procedure and had the same results, none broke.
I still have the Lisle tool, and if I never use it, that's fine with me. It will still have been a good investment just from the standpoint of peace of mind.
t_money662
1997-2006 Expedition & Navigator
06-26-2006 07:08 PM
