Turboless diesel
#62
Received 3,101 Likes
on
#63
#64
Disabling glow plugs is a common tactic to safely use ether as a starting aid. Someone may have suggested to disable them so they don't melt down and cause you more problems. Most of them really are trash.
If you try to get the cheap glow plugs out, and they break, you're really not in any worse of a scenario as you are now with them in there.
Plugging the block heater in does aid in starting.
#65
Is it possible for the tips to fall into the cylinder?
#66
Yes, if they start to get crusty and fall apart...or mushroom so large on the end that they can't fit out through the hole.
If either of these scenarios occur, you're pulling the head anyway so there's really nothing to lose sleep over. If you break them upon removal, at least you didn't find out they fell apart by way of a huge compression loss.
#70
Try to pull the glow plugs out with head off? No, that'd be like walking over to the trash can, bringing it back to your desk, throwing a piece of paper into the trash can, then walking the trash can back to its place.
Best to try to remove the glow plugs, then remove the head if necessary. If someone just had the glow plugs changed, it shouldn't be a problem. Just check the ends that go into the chamber to make sure they're all in tact.
#73
on
#75
