64-66 F100 styleside tool box
#31
#32
HI ,i have not took it apart yet but will have a couple if you get some more made just in case i may need one in the future,just let me know dollar amount and will post you the cash
cheers
Gary
garymartin@vodafone.co.nz
cheers
Gary
Chad - made the springs for me. He killed it!!! I had him made theee for the just in case factor and need for the future possibility. They are identical to the original and work amazing. Don't even hesitate to order them from him!!
If you have any questions about thwm
let me know.
Cheers,
Lax
#33
#35
#37
Hello everyone first of all I would like to apologize if I seem a bit lost. I'm a new member so I'm still learning my way around. I have been a long time reader as I have been restoring a 66 F100 short bed I picked up about a year ago. I have learned so much from everyone on this forum and would like to thank you guys for all the help eventhow I was not a member. Ok back to my question, I know that these tool boxes are hard to come by but would anyone be able to lead me in the right direction to where I can find one??? I'm actually just missing the door and hinge and once again it's for a 66 F100 short bed.
Thanks
Thanks
here's this one
#38
#40
on
#41
Gary, I'll take some pictures for you in a little while - but it is the combination of the hook on the back of the movable latch handle and the clevis pin that holds the handle to the main plate - both of those in tandem allow the movement of the handle to push down on the latch and spring.
Chad
Chad
#42
on
back photo
inside photo
lock mechanism
has you can see all my internals are missing dropped along the road somewhere in new zealand
would like a another lock if anybody has one used or new,i am going to buy an electrical solenoid to put on the inside for now to keep the door latched but would like an original one for the future
#43
Gary, the handle with the lock in it seems to be missing the hooks. The hooks on the back side are spot welded to the handle and it's the hooks that do all of the work of both containing and pushing the spring and latch down. The example here is missing one of the 2 hooks but you can see what they look like. Mirror opposites of each other.
Chad
Chad
#44
One other thing to note - I don't believe you'd want to drive your truck down the road too far without the tool box being locked. Reason is if it's not locked then the handle can pivot outward and the weight of the internal latch will likely push the spring down when going over bumps so the handle can pivot outward as the latch moves down and the door could fall open. A good new spring might help, and even a slightly longer spring might hold it shut with no issues at all, but the beauty of the lock being locked is then the handle holds the latch in it's upward position and the spring wouldn't be impacted by going over bumps since the latch can't move in this case.
As Dave E. says food for thought....anyway.
Chad
Chad
#45
Looking for a tool box latch assembly
I know know this is an old post. Anyone have any leads on where I might find one of these latch assembly kits?
Thanks
Thanks
Both of these lock assemblies came in the kits. I wonder how many more of these kits are out there? Interesting about an F100 being a 99A and an F250 being a 99B. The difference in the size of these templates gives some idea of the difference in sizes of the two boxes (SWB versus LWB).
Attachment 211460
Attachment 211461
Attachment 211462
Attachment 211463
Attachment 211464
Attachment 211465
Attachment 211460
Attachment 211461
Attachment 211462
Attachment 211463
Attachment 211464
Attachment 211465
Tigger!
36
06-22-2011 03:31 PM
HankMurphy
02-19-2008 10:30 AM
