Help
Old Nov 13, 2016 | 01:31 PM
James Rechtiene's Avatar
James Rechtiene
Help
I'm new here and I'm having a issue with my 7.3. I had to replace the o rings in the filter bowl and now my truck won't start. It will hit on starting fluid but it will not catch and run on Its own. Any suggestions.
Old Nov 13, 2016 | 02:23 PM
BBslider001's Avatar
BBslider001
First HUGE suggestion...DO NOT use starting fluid I less you want to blow up the intake and do other damage.
Do you have Pressure at the fuel bowl when cranking over?
Old Nov 13, 2016 | 04:24 PM
BuddyBarnes's Avatar
BuddyBarnes
Check the fuel bowl heater fuse. I think it is #22.
Old Nov 13, 2016 | 06:14 PM
tshrager's Avatar
tshrager
Ether and glow plugs are a no no. Like said, you an check the fuel pressure while cranking at the schraeder valve on the side of the fuel bowl. Do you have wait to start light?
Old Nov 13, 2016 | 06:55 PM
ReBilld's Avatar
ReBilld
Make sure you got the wiring harness plugged back in on the passenger side of the fuel bowl, and make sure the IPR is plugged connector is plugged in.
Old Nov 14, 2016 | 12:44 PM
madpogue's Avatar
madpogue
The fact that there wasn't an explosion with the starting fluid suggests the GPs aren't working. This could be a stand-alone issue or part of a larger one. Preliminary questions -
- Does the WTS light come on?
- Does the tach move while cranking?
- Any smoke from the tailpipe while cranking?
Old Nov 14, 2016 | 01:10 PM
knottyrope's Avatar
knottyrope
follow this chart
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Old Nov 14, 2016 | 04:56 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Yeah. What knotty said. And slider.
Old Nov 14, 2016 | 06:50 PM
z31freakify's Avatar
z31freakify
Sounds like you have trapped air it will take lots of cranking time. And like Byron said don't use ETHER!! With your glow plug relay connected.
ALC97
21
Mar 17, 2018 11:03 PM
jperry1213
16
May 15, 2016 09:52 AM
finerant
Apr 16, 2015 12:17 PM
n.o.yat
20
Aug 6, 2010 07:51 PM
PCola
Apr 11, 2008 09:53 PM
