Things were going to good.... Flexplate Touching Bell Housing
As I suspected, things were going a little to smoothly..... While I was doing some prep work for the headers today I gave the flex-plate a little look over and felt for the clearance on the bell housing and Sha Zam ! its touching and at certain points of the rotation by hand it will grind .... When we were bolting everything up it was fine and went through several hand crank rotations..... then everything was tightened down and the motor mounts torqued down...... Is this a normal clearance thing ? What should I have done differently ? What now ? loosen everything up and hope it realigns ? Excuse the sarcasm, im slightly pissed off......
Follow up
Got everything loosened up, tranny bolts out, starter out, motor mount nuts off .... And its NOT touching the bell housing, but with a feel of my small pry bar it dose not have much clearance, does anyone know how much clearance is spec for the flex plate at the bottom of the bell housing? I have a feeling that If i bolted everything back up, it will be touching again....
Updated !
Well I got the engine loose from the torque converter with a gentle lift on the Cherry Picker and instantly heard a settling noise....... Got under the truck and the torque converter was much more comfortable then before with added movement within the bolt holes in the flex plate and I got that "clang clang" that you want to hear indicating its free floating. I have a few different theories on why the motor was bound up.... We didn't pay much attention to the order in torquing things down when doing motor mounts, tranny bolts and torque converter..... I also had a T-handle valve cover bolt that was jammed up against the master cylinder, although you really couldn't tell until everything was secured..... Either way no rubbing now, everything cycles smoothly and I got new torque converter nuts like NumberDummy suggested........ Starter is back in (PITA) and headers are almost on, naturally I now have a header bolt hole that is not keeping the bolt tight, shes worn out .......... always something......
somcpeek
1997 - 2003 F150
04-16-2018 12:57 PM
Sycostang67
General Automotive Discussion
17
07-31-2009 01:34 AM
h-m
10-18-2005 03:41 PM
