Great Whites slow but steady rehab
Thanks guys for all the kind words. I am curious what kind of shape whites mill is in. Its amazing how much it's deteriorated in the last 30k miles. But I'm 99 percent sure it was on past borrowed time before my posession.
Nothing is in stone. I really would like a 369 just because not many others have one. But I have 0 fabrication skills and trying to do it over a distance isn't fiesable. I was thinking 38r just for ease of install. But like I said nothing is for sure.
NO, bought it at 178K and retired it account to hot to handle at 201K. Just after I bought the Mare I took it to John Woods for a trans. He asked if I wanted the towmaster on a stock motor. I said its not going to be stock long! I then put it in my nephew's garage right away right next to the Mule and started switching parts. I put the studs, valve springs and push rods in also. Water injection went on right away. I might have pushed the EGT's a little cresting hills but I never over rev it. This really makes me curious?!?!
Nothing too special I dont think. A straight edge that can span the bore and a snap gauge or measuring devise of your choice. Obviously gotta make sure the block is clean and you have the ability to note where in degrees of rotation your crank is (not totally nessessary), something I'd do but I'm ****... You'll need to figure out the reference pint that the MFG uses on the crown of the piston too (again not totally nessessary) but....
#29
