I'm new here and I'm having a issue with my 7.3. I had to replace the o rings in the filter bowl and now my truck won't start. It will hit on starting fluid but it will not catch and run on Its own. Any suggestions.
Ether and glow plugs are a no no. Like said, you an check the fuel pressure while cranking at the schraeder valve on the side of the fuel bowl. Do you have wait to start light?
The fact that there wasn't an explosion with the starting fluid suggests the GPs aren't working. This could be a stand-alone issue or part of a larger one. Preliminary questions -
- Does the WTS light come on?
- Does the tach move while cranking?
- Any smoke from the tailpipe while cranking?
