My 97 f350 7.3l water in the fuel light started coming on after I filled up on Monday and I went to go drain the bowl and nothing happened so I'm guessing it's clogged any idea on what I should do?
Um, the drain is on the bottom; no pressure required. But with the filter cap on, nothing will drain, just like holding your thumb on the top of a soda straw. Loosen the cap and the drain will start to run.
When I had the OEM fuel system I always opened the valve with engine running. If the drain port has debris prevention flow pressure from the pump usually is enough to push it out. Never had an issue doing this but closed the valve after 5 seconds or so.
