Trying to Jog Members Memory
Old 02-26-2016, 09:58 PM
lbrauer's Avatar
lbrauer
lbrauer is offline
Hey family members back around 2010 or 2011 I think there was a thread showing at what angle the drive shaft needed to be to reduce vibration and help with the u joints but I can't seem to find it in the search tab. Do any of you remember the thread and can you recall it. If I am not mistaking it showed an angle gauge on the drive shaft showing the right degree it should be set on. And by the way I need to know at what angle should a 302 engine should be set at in a 52 F1. If there is information out there please point me in the right direction.
Thanks in advance,
lbrauer
Old 02-26-2016, 10:09 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
The angle of the engine is dictated by the angle of the carb on the intake...usually around 6 degrees. Whatever angle you end up with at the engine/trans is the angle you want at the pinion. IE, if the engine/trans is pointing down 6 degrees then you want the pinion pointing up 6 degrees. Lots of diagrams and tech info on the interweb.
http://www.hotrodhotline.com/md/html..._harmonics.php
Old 02-26-2016, 10:28 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,450 Likes on 1,397 Posts
You're probably thinking of this story, written by our very own, brilliant John Niolon. It's one of the best tutorials on driveline phasing I've ever read.
DRIVE LINE PHASING
Old 02-26-2016, 10:43 PM
lbrauer's Avatar
lbrauer
lbrauer is offline
Thanks Charlie that is great information. I thank you much
Old 02-26-2016, 10:46 PM
lbrauer's Avatar
lbrauer
lbrauer is offline
Hey Wayne that is the one I was referring to. Thanks for the reply and the find. Thanks again.
Old 02-27-2016, 07:32 AM
CharlieLed's Avatar
CharlieLed
Somebody had posted a link to a video on driveshaft phasing some time ago. It's really an eye-opener...I'll try to find it and post the link.
That was quick: http://www.macsmotorcitygarage.com/2...e-and-phasing/
Old 02-27-2016, 08:56 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Thanks in advance,
lbrauer
There is no "correct" angle to set an engine to, but with a carbed engine you want the carb mounting pad to be level with the vehicle at its normal going down the road rake. With the carb pad level the crankshaft will normally be angled down about 3 degrees.
The important part is to match the pinion angle to the engine angle, again with the vehicle at the angle it will be on the road. So if the engine is angled down 3 degrees you would want the pinion angled up 3 degrees. I have run up to 5 degree angle on a fuel injected engine to deal with front accessory clearances, but FI engines are not a picky about angle.
I have pictures of setting this up in my truck #2 build thread, I am running 4 degrees on that truck.
Old 11-06-2016, 12:01 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
Exclamation 404
looks like bad link above (or rather page was moved)...
found it here:
http://jniolon.classicpickup.com/dri...nephasing.html
DRIVE LINE PHASING
Ratty51F1
07-18-2019 04:31 PM
c91x
07-14-2015 03:43 PM
david53ford
04-05-2009 02:00 PM
rat49f6
08-20-2008 09:29 AM
learpilot
08-17-2004 07:57 PM
Quick Reply: Trying to Jog Members Memory
