2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
FORScan Spreadsheet
  #4576
Old 03-12-2019, 05:52 AM
Arkyman
Arkyman is offline
Arkyman is starting off with a positive reputation.
Is There an Equivalent Tool for a Cadillac Escalade?
New to the forum and hopefully this isn't off-topic. I have a 2018 F-250 and I love the idea of using ForScan tool to manipulate the features and accessories on it (purchasing the interface now). My wife's vehicle is a 2017 Cadillac Escalade. Does anyone know if there is an method of modifying the codes on them, similar to ForScan for the Fords? Thanks.
  #4577
Old 03-12-2019, 09:50 AM
mhoefer's Avatar
mhoefer
mhoefer is online now
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
Don’t know but I am sure if you could find a forum like this for GM/Cadillac they would be able to tell you.
  #4578
Old 03-13-2019, 07:30 AM
mattymax
mattymax is online now
mattymax is starting off with a positive reputation.
Originally Posted by orion1968 View Post
Anyone else notice on the 2019 that Police mode is already enabled? When I went to program my new 2019 F450 it was already enabled.
Mine is already activated from the factory. 2019 F-350
  #4579
Old 03-13-2019, 03:40 PM
larrymul's Avatar
larrymul
larrymul is offline
larrymul is starting off with a positive reputation.
Can someone explain Police Mode? I don't find it on the spreadsheet as an option. Is it available on a 2018 F-350 SD?
Never mind, a simple search found the answer.
  #4580
Old 03-13-2019, 03:53 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Larry, it's line 12 of the sheet...
  #4581
Old 03-13-2019, 04:15 PM
larrymul's Avatar
larrymul
larrymul is offline
Thanks for the reply Karl, but line 12 on my spreadsheet, which I'm told is the latest for my 2018 (2017 F-350) is speedometer recalibration for different size tires.
We must be on a different playing field, lol.
  #4582
Old 03-13-2019, 04:53 PM
Greg Hamilton
Greg Hamilton is offline
Greg Hamilton is starting off with a positive reputation.
Yep... made it standard on the 2019s!!!
  #4583
Old 03-13-2019, 05:06 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Line 12 on the spreadsheet linked on the first page of this thread, the only 2017+ SD spreadsheet I know about, is secure idle (police mode.)
  #4584
Old 03-13-2019, 06:46 PM
SalineLakeFord
SalineLakeFord is offline
SalineLakeFord is starting off with a positive reputation.
Anyone having trouble with bambi mode on 2019 F250 Lariat? I have halogen lights. My factory setting is the same as the “new” setting on the spreadsheet.
  #4585
Old 03-13-2019, 07:39 PM
Richard Aarts
Richard Aarts is offline
Richard Aarts is starting off with a positive reputation.
try the other one that says halogen and some leds
  #4586
Old 03-15-2019, 01:27 AM
ADB Super Duty
ADB Super Duty is offline
ADB Super Duty is starting off with a positive reputation.
I am having issues with the OEMhalogen to OEM led conversion process using an aftermarket harness from black flame customs. I have a 2019 f350 and after using the conversion harness I am getting flickering in the headlights. For High beams I get 3 of the 4 lights on, and they pulsate constantly. I did the oem halogen to led conversion but even though my truck originally had halogen headlights when I changed to OEM h
led headlights, I noticed in FORScan that the as built FORScan code was already set to the
LED. Set to The oem halogen code (which it wasn’t in original as built) everything seems to work well but I still get the pulsating up from.... anyone have any recommendations for me?
thanks
  #4587
Old 03-15-2019, 07:19 AM
Afasano
Afasano is online now
Afasano is starting off with a positive reputation.
thanks
i just did the swap last weekend. Get rid of the harness and add the 2 pins to the bcm. It worked flawless the first time. Search “how to” halogen conversion. There’s a great right up with step by step instructions. Everything works as factory.
  #4588
Old 03-15-2019, 10:28 AM
Mkos1980
Mkos1980 is online now
Mkos1980 is starting off with a positive reputation.
Whenever my lights turn on the fog lights do to when selected. Was this not happening with the older trucks as I noticed there is an Forscan to keep the fogs on when the lights are turned on?
  #4589
Old 03-15-2019, 10:35 AM
wildcard30's Avatar
wildcard30
wildcard30 is offline
wildcard30 is gaining momentum as a positive member of FTE.wildcard30 is gaining momentum as a positive member of FTE.
I believe it’s a “remember last setting” hex code. If you turn them off before you turn off the truck they should not come on next time.
Its been a while while since I was in the spreadsheet but there may also be other settings for the fogs.
  #4590
Old 03-16-2019, 06:55 AM
orion1968
orion1968 is offline
orion1968 is gaining momentum as a positive member of FTE.orion1968 is gaining momentum as a positive member of FTE.
The other setting for Fogs is bambi mode.
Quick Reply: FORScan Spreadsheet
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
