2017-2019 Super Duty FORScan Spreadsheet
#4381
I downloaded version 2.3.19 to replace my previous version when I couldn't get my old Forscan version to accept a new extended license. The new version wants an activation.code as well as an extended license.. How do I obtain an activation code.
#4382
Yes I have the Bluetooth OBDII and the tablet is Bluetooth capable and never have an issue and yes have a windows 10
#4385
#4386
Finally got around to doing this on my '17 after receiving the MX last trip home. Like most I was a little nervous but once I backed up the AS-Builts there was nothing to it!
Got rid of the horn honk, enabled "Police Mode", and got the fogs to stay on with the highs.
Thanks for all the contributions to this thread guys, much appreciated!
#4387
I ended up downloading 2.3.18 and wasn't asked for an activation code. I still couldn't get the extended license to work. It turned out the date wasn't right on my tablet. After correcting the date it worked like a charm.
#4388
Hmmm... just downloaded .19 a couple days ago but haven't tried it in the truck. My license is good for another 10 days so will stick with R.18 unless I hear .19 is working w/o issues or an 'activation code'. I just got pretty good with .18 and connectivity and don't want to gum up the process with a new step. Hopefully .18 will continue to work after I get a new ExL. Or maybe your problem was an anomoly 4by4ord with date incorrect?
#4390
#4391
#4393
#4394
I did a speedometer recalibration for 35” tires following the procedure recommended on the spreadsheet for the BCM module, key position 726-12-01 (xxxx xx4C xxxx).
I now get a DTC code P160A with malfunction indicator lamp off on the Power Control Module.
Is this something to be concerned about?
#4395
