2017-2019 Super Duty FORScan Spreadsheet
#4366
Did the Auto-Regen disable mod today. Gauge shows and is selectable 0n/Off. Looks like I'll get a screen notification on every key-on telling me it's disabled.. I can live with that.
Truck is just short of 1000 miles and DEF is at 65% so figured it might regen today on my way to the vet (5 miles) and didn't want to interrupt it if it does happen. So I'll let it ride until the idjit meter tells me I have to Regen and switch back to Auto Regen and see what happens. Planning a 100 mile round trip just for this purpose when I know the roads are clear.
I neglected to punch WRITE in both IPC and PCM the first go-round.. d'oh. Works fine when done correctly.
Also added Panic 2-button push.
#4367
#4368
#4370
Q: if I were to purchase a WINDOWS-based tablet to use solely for FORScan work, what requirements would I be looking-at...I have a Windows 'boat anchor' PC and Apple iOS hardware, but nothing Windows portable...so, in order to function properly at my vehicle, what is, say, the minimum RAM, Processor, obviously Bluetooth to use with the MX+ OBD2 interface, etc...again, if I can get something inexpensive enough, this could be dedicated FORScan hardware...thank you.
#4371
Got the incorrect LED for front turns (there are 2 options and my guess was wrong of course). So, while reading the description for either front or rear LED turns they mention the fast flash shows up on the dash display, not necessarily the bulb which would require the resistors I don't want to clear the dash fast-flash.. hmm. I know someone posted they had the issue on the dash. Was this even with the FORScan mod done or did that prevent the dash flash too?
I can live w/o LED turns.
Thanks.
Thanks.
#4372
#4374
I down loaded forscan and followed the procedure to make some changes to my 2017 F350 about a year ago. I've actually forgot most of how I did it but a friend has asked me to make the same changes to his truck. Can I use my Forscan software and OBDII connecter on his truck or is the software somehow linked to my serial number?
#4376
#4377
#4378
Yeah, my plan is to have the owner of the truck I'm modifying bring his own formatted thumb drive to load his as-built and modified data on. In the event something were to happen to my computer or my life he'd be able to recover data by just enlisting someone else who has FORScan. I don't want to be responsible for holding that information.
#4379
Thank you and DCM1 for your help. I like the idea of storing his as built files to a thumb drive for him, or, depending on the size of the files ... maybe I could save them to my laptop and send them to him as an attachment in an email?
#4380
Not showing extended license
THINK I FIGURED IT OUT AS i NOW HAVE WARNINGS ABOUT CHANGING PARAMETERS BUT NOW DON'T SEE HOW TO SAVE ALL THE ORIGINAL MODULE CONFIGS TO HAVE A SAFETY BACKUP
I followed the beginning instructions..but forscan still says I need extended license... It just downloaded a regedit string I can see in sheets..what gives? Please help
