2017-2019 Super Duty FORScan Spreadsheet
#4351
#4352
on
Does anyone know if on a 2007 F-250 Super Duty XL if I can add the "fuel mileage left until empty" on the message board above the mileage reading? I was looking at a 2005 and I seen it had that option displayed and would like to have it if available. I can not find a forum anywhere on what you can and can not do on a 2007 with Forscan. If anyone has a link or can shed light on this Thank you
#4353
Parking Lamps with Low Beam DRL Confirmation
BCM 726-26-02 x0xx xxxx xxxx Changed to x1xx xxxx xxxx
Overcast day so had to be sure there was no demand for headlights on Auto. There was not.
DRL OFF dash display, truck in gear = NO lights
DRL ON dash display, truck in gear = Low Beam + front and rear Parking Lights.
Spreadsheet Line 38 shows Waiting Confirmation so here's one.
#4354
There is a good chance I missed this but....
I enabled "Show Temps on Gauges" in IPC as built. Is there another line to get the oil temp to show above that gauge?
I believe someone said that is just the way it is and you have to go to engine info screen to see the actual temp.
can any one confirm
can any one confirm
#4355
can any one confirm
can any one confirm
#4356
#4357
I must be doing something wrong. Ive been trying to connect for 4 hours with no dice. it says wifi then says no elm found. im on a labtop with a corded elmconfig module. module is lit up with one red dot it says instructions to select obdii port in the config but I don't have that option. its all "auto" any advice?
#4358
#4359
Got it to work, but kind of disappointed. I added ambient lighting to my 19 along with 4 of the led under the seat and footwells and it lit up and I have the color changing icon on sync. Come out an hour later and although I still have the icon, no lights. Reload same thing and I have lights. Come out this morning no lights.... thoughts?
#4360
I am wondering since the 19s don't have an Ambient lighting if I have to leave stuff alone since it keeps erasing. I pulled up my build vs same truck with lariat ultimate and for the ambient lighting this is what I have vs the truck with ambient 7D-01-02 Mine 0089 0004 80E7 Other truck 0289 0004 8AF3 Wondering if I should put a 2 in the first set...
#4361
You can do the FORScan changes for both front & rear LED 'turn outage' from the Plain English part of the BCM/BdyCM. No need to enter hex codes in the as-built portion. I've confirmed that here and with the vendor I got my LEDs from. Pretty sweet. I too did not want hot resistors wired in. Waiting on my front LEDs to arrive tomorrow to get them done.
I can live w/o LED turns.
Thanks.
#4362
From where on FORScan Lite do you usually monitor if it's on all the time, or if looking for a regen, or DPF data, etc.
I'll figure it out; I just installed Lite and will play with it. Since it's monitor only I can mess with it all I want with no potential for mistakes.
its the indicator that will show you when the truck is in REGEN mode
#4364
Wow 291 pages of FORscan since my last bookmark at page 4
2019 Superduty came, key fob honk still there and was the first change to go!
Noticed the 'SecureIdle' police mode we all loved so much is enabled from the factory on this truck so that was a welcome surprise.
Still saving backups of stock configs and tinkering as I go, finally have an MX so going to try a few IPC changes for temps and see where we get too.
Merry Christmas everyone!
2019 F450 Platinum
Double Horn Honk - BodyCM - YES
SecureIdle - BodyCM - FACTORY ON THIS 2019
Heated Seats to screen - APIM - YES
Enter NAV while moving - APIM - Modified/Trial
Show temps on gauges - IPC - Updated to .19, IPC Writes now - YES
Added DPF% to screen - IPC - YES
Added Global Window Close - IPC/PDM/DDM/BCM - YES TO ALL
Disable Driver Seat Belt with IPC - YES
Added Manual Regen - YES
**2019 has no CD slot and delete the screen icon shows same APIM programming as spreadsheet.
2019 F450 Platinum
#4365
2019 F450 Platinum
Show temps on gauges - IPC - FAIL/NO IPC ON 2019 YET
2019 F450 Platinum
