2017-2019 Super Duty FORScan Spreadsheet
#4126
on
Something I recently learned. I set my lane change indicator to flash 5 times. I had to tow a cargo trailer this weekend and when I used the lane change feature it would flash 8 times. I thought I might have had some issues but when I disconnected the trailer the truck went back to a 5 time flash. Reinstalling the trailer caused it to go back to 8 flashes. I can accept that.
Also, I was going to check with Forscan if anything changed. I realized that my hard drive on laptop failed and I no longer had Forscan or my backups. I have to start all over with a new laptop and hopefully can get another backup except this time on a thumb drive. This laptop was used exclusively for diagnostics so no other data lost. Just a word of advice. Save your original configuration on a thumb drive or SD card for safe keeping.
https://www.motorcraftservice.com/AsBuilt
You may need to select the county you are in, but then reload the page. You input your VIN and it will give you your truck’s as-built info.
#4127
2017 F250 Value Lariat
I updated to Sync 3 version 3.0. Changed to Nav in motion, and power point time out all basically at the same time. Now when I turn the truck off and on, several times it has defaulted to FM source instead of staying on Sirius with home page it had when shut off. It had never did this before, It always started up in the last setting. It does not lose the memory settings. Does anyone know if this is tied to any of the forscan changes or if it's in the Sync 3.0 update? TIA!
#4128
#4129
Two flashes are added automatically when trailer is attached.
https://docs.google.com/spreadsheets...s1s/edit#gid=0
#4130
Aaron
#4131
If you lost your original as builts go here.
#4132
Hi everyone
I have tried reading all the posts here. My mind has glazed up but I think I have a basic understanding of how to do this.
1. I need and OBD adapter.
2. I need to register.
I have a windows 10 laptop
My truck is a 2019 F350 Lariat CC turbo 4x4 with the ultimate package.
I am primarily interested in numerical values for the engine gauges.
I have seen no comments for the 2018/19 trucks and I have noted that some of the modifications that you mention are now incorporated into the 2019s.
Are the values for the 2017 the same for the 2019's?
This has all been interesting reading even if it isn;t transferable to the 2019's.
My appreciation and regards
Bill
Bill
#4133
Just a warning to everyone who uses this: The as-built data on that site is NOT the same as what is in my truck according to FORScan. I have found many codes that are different.
#4135
Hi everyone
Bill
Bill
#4136
#4139
#4140
Moto, is the error on the three tires image taken right after you updated? I think you will need a few drive cycles to let it update settings and turn off the warnings if you aired down without moving the truck? Just a thought because I remember adjusting mine and then several days later airing down. I only adjusted to 55 psi front and rear, that’s as low as I can go with the diesel up front.
