2017-2019 Super Duty FORScan Spreadsheet
#3226
#3227
To switch to the Lincoln Black Label splash
APIM As-Builts, 7D0-02-01
xxxx-x3xx-xxxx 3= Lincoln Black Label
...and another:
xxxx-xExx-xxxx E= Continental with swirling stars
And from post 2495:
To change to the gold tone Lincoln colors...
In APIM:
7D0-01-02 change to 8xxx-xxxx-xxxx
7D0-03-01 change to xxxx-x2xx xxxx
Video I found here:
#3228
Is there anyone in the Chicago western suburbs that has this device? I looked into it, but I have all Apple products. I want to change the TPMS sensitivity in the rears. Maybe enable the police mode and disable the double horn when exiting the vehicle. I would be willing to pay for gas and time or meet you somewhere.
#3229
FYI: I've added some adapters to my FORScan tutorial capable of doing normal FORScan changes as well as doing firmware updates when that future version is released.
I think I've already mentioned here that any Bluetooth adapter won't be able to keep up with firmware flashing but it is now the general consensus in the testing group (and with the FORScan devs) that the normal ELM27 USB adapters are not up to par for doing firmware either. I highly recommend a proper J2534 adapter for anyone considering this. In a recent test of flashing IPC firmware with this test version of FORScan, an ELS27 adapter (fastest ELM327-compatible adapter available) took 1 hour 20 minutes while the same process took 20 mins on a J2534 adapter.
The UCDS adapter I list from Russia in my tutorial is my go-to adapter for any FORScan or firmware updates; I own two of them just in case one was to break...this is how much I like this adapter.
#3230
#3233
#3234
The end-bars remaining in brighter-mode WITH the headlights on may be too bright of a combination and cause the turn signal to become less visible. As it is, the end-bars stay lit when the turn signal is used.
#3235
#3236
I get the the Tailgate Ajar warning when I filp that bit, but I get it every time I turn the truck on, regardless of whether or not the tailgate is actually open.
#3238
Any one know if it is possible to change the outside LED headlights to be at their brightest when you unlock the truck or open the door?
#3239
How can I download the spreadsheet? Every time I try to save as XLS, it says corrupt and cannot be saved.
Tried several times, same result, cannot copy and paste either, won't copy.
How do I get a copy of this for my HD so I don't have to be online to view the spreadsheet? Windows 10 computer.
#3240
