2017-2019 Super Duty FORScan Spreadsheet
#3166
[QUOTE=IamLee;17803822]I didn't try modifying the as built just the factory select options. My truck came with 4.30 gears and 275 70 18s (now running 37s) I changed the ratio to 3.73 and I think I tried 275 65 18s and a couple extreme moves ie 3.31 gear and 20s just to see how it affected the speedo but the Speedo was off exactly the same as before
#3168
[left][QUOTE=nbayless36;17805060]
Good thought but I'm sure the computer references the wheel sensors, which gearing wouldn't have an impact on. I'm assuming there is not a speed sensor in the trans.
#3170
#3171
Finally got the BT dongle setup on my laptop so I was able to connect to my truck . Quite the process to save all the as built modules , but I think I got it done . I added regen screen , heated/cooled seats , heated steering wheel to the nav screen . Also added digital temp above gauge .
Question though , is there a way to add oil pressure above gauge ? And is there any more clarification on the operator commanded regen ?
Thanks for this thread , I couldn't have done it without all the input from the members here !!!!!
#3172
#3173
I purchased the adapter and their software so I paid:
100 Euro (adapter)
10 Euro (1 token lvl 1)
80 Euro (extended license)
10 Euro (shipping)
200 Euro total
If you only want to use it for FORScan you can probably just buy the adapter for 100 Euro. If so, message them on that page about it saying you just want to use it for FORScan and don't need their software.
100 Euro (adapter)
10 Euro (shipping)
200 Euro total
Sorry for the somewhat double post, should have multi quoted.
#3174
No need to get defensive. First hand experience for others has shown issues or I wouldn't have posted what I did. So, I was trying to prevent new folks from having a potential problem with an adapter that works for some but not all. I'm glad it worked for you though.
#3175
#3176
#3177
Have used Forscan successfully previously. Tried to use it today and I keep getting a license error. Extended License error. I reloaded the license key I've gotten previously and it does the same thing again.
Is the original key only good for 1 profile? I had to recreate mine.
#3178
bummer... I was hoping that would be a work around.
#3179
#3180
Finally got around to setting up and getting everything I wanted done. My question for the group is for DRL's. I have a 2017 250 KR Ultimate with LED headlights. I want to run my DRL "C" and fogs. I believe you can add the two digits, but want to know if anyone has tried it. Thanks
