2017-2019 Super Duty FORScan Spreadsheet
#3136
So I've done a lot of changes so far with FORScan but one that I'm having issues with is the fog light switches off with turn signal mod. BCM, 726-28-02. My as-built is 0000-0000-0057, and when I make the change in the spreadsheet to 0000-0100-0057, I get the "incorrect checksum error" and it changes the new value to 0000-0100-0058. However, the change doesn't work. With the headlights and fog lights on, the blinker doesn't switchback with the fogs, but the respective fog light just stays off. So with the left blinker on, the left fog is just off, no blinking. Has anyone run into this? Thanks!
#3137
Ok. I was able to get rid of the double honk and set the police mode. Also changed TPMS sensitivity. However, I cannot find the IPC module to enable the digit temp above the gauge. I am using the OBDLink SX with the USB connector. Any ideas on where to find the IPC module?
Also, can I turn the rectangle LED driving lights off with the turn signal?
#3138
#3139
#3140
#3141
#3142
#3143
#3144
#3145
#3146
PM me and ill hook you up with any of my backup files.
#3147
#3148
What Tom is referring to is the heat cycling of the wheel. His wheel, like yours, doesn't shut off and turn back on. It stays on but the level of heat it outputs cycles. What he (and I) would like to achieve, is to have the heat output constant.
#3150
In case anyone else runs into the "Can't Identify Vehicle" issue, it may be because your vehicle is "too new". Got a return reply from ForScan support saying this was my issue. They are anticipating a fix in 2 to 3 days.
My guess is that this kind of message may be an ongoing issue as newer trucks are delivered.
