2017-2019 Super Duty FORScan Spreadsheet
#3121
Originally Posted by coolemoff1
worked with forscan a bit today with my 2017 f 250
enabled heat seat icons only on radio
enabled dpf mode gauge
enabled bambi mode and it worked fine ,but it turned the dpf gauge off strange!
turned bambi off had to tuern dpf on again this time it stayed populated on
,anyone have any insight on this one !
ran out time to tinker lil more, will this weekend if its nice out
#3122
2016 Super Duty Spreadsheet
Does anyone know what forum the "FORScan 2016 Super Duty" spreadsheet is discussed in?
It was mentioned in this thread in post #381
2016 Super Duty - https://docs.google.com/spreadsheets...gid=1691531693
#3123
6.7L Power Stroke Diesel Forum
https://www.ford-trucks.com/forums/1...uilt-data.html Post #4
#3124
#3125
I started a thread with this question, but I didn’t get an answer. I’ll try to re-ask it here.
I bought a nuvision tablet and the obd mx scan tool. I got everything hooked up, backed up. I then successfully changed my tpms to match my tires. After, I tried to change my fog lights to stay on with the high beams. I get this error. “This adapter has CAN bus compatibility problems and can not be used in some functions.” Any ideas what I may be doing wrong?
#3126
Neither of these work?
Fog Lights with High Beam LED and some HALOGEN.
BdyCM as built: 726-27-01, xxxx xxx1 xxxx to xxxx xxx0 xxxx This allows LED fog lights to stay on when high beams are also turned on. This code has been confirmed to work with some halogen headlight trucks also. Also known as Bambi mode (to see deer better).
Fog Lights with High Beam HALOGEN.
BdyCM as built: 726-27-01, x0xx xxxx xxxx to x1xx xxxx xxxx This allows Halogen fog lights to stay on when high beams are also turned on. Also known as Bambi mode (to see deer better).
#3127
#3128
#3129
yup, got the extended license. That’s my thought too. I got the TPMS adjusted, confirmed that it worked. My second was the fog lights. This is where I got the error. I haven’t tried anything else.
#3130
#3132
#3133
Alright, here’s my update. I went back out and tried the change again, no luck..... I got the same error. I decided to try another change. I successfully added the digital reading to the gauges. Then I tried to add the Bambi mode using the halogen code. It accepted the change, but since I have LED’s it didn’t work. So, I changed that code back to the original code and retried the code for the LED’s. This time it accepted it and worked! Thanks everyone for your help!
#3135
Microsoft has no idea if your old computer is still registered or in use. Therefor, you can run the same Windows key on more than one machine. To be honest, you likely wouldn't need to register your copy of Windows to get it up and running in Bootcamp enough to use Forscan, but I think it would register without issue irregardless. I used my old Windows 7 disk as well which is still installed on an old laptop of mine. No problem there and was able to register. However, if your worried, complete the installation without registering your key and just run Forscan. You don't need to do Windows updates or anything so registration is a step you could theoretically skip.
Hell one of y’all good buddies want to donate a copy and the register code. If their not checking should be no problem.
